Wiring help...last resort
Hi,
I'm needing some pin outs for a KA, anyone got an old manual lying around?
I've done this conversion a few times, but its been a while. doing it for a friend but ive lost my old manual....(it was burned,lol)
Im needing the following pins numbers if anyone has em, dont fancy buying a book just for the sake of it
The zetec connector block ive got has the following pins/wires
1 violet/blue switched 12v run and crank
2 black/blue fuel pump relay
3 white/black tacho
4 black red -
5 violet blue switched at 12v battery
6 black green oil pressure
7 blue orange 12v contious
8 violet yellow switched 12 v run
9 red white diagnotic
10 violet black ac signal
11 black blue ac signal
12 brown/green temp gauge
I'm need pin out for ka wiring...if anyone can help
3 white/black tacho
4 black red -
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Mark RS
Oct 12, 2015 06:01 AM
