Who makes a Turbo spacer for a T4
I need to raise my T4 up by about an inch ,does anyone make a spacer for these ?? Even tho its a T4 im led to belive the flange is called T3 is this right ??
Hmmn , i think theres was a spacer designed to go between the 2 sections of the exhaust manifold , i need to lift the turbo up from the top flange on my manifold as its a tubular jobby .
Yeah the RS500 style T4s used a T3 flange.
Try Cr Turbos mate, they have spacers on the shelf iirc, and they're availble in different thinknessess. I've got a pair of 20mm ones from them, just need longer studs/bolts to hold the turbo to the manifold.
aka Turbosailorboy
From: Under the water.... .......in a nuclear submarine
Hows this Tony ? You'd obviously need to blank off the external take off hole
http://www.ebay.co.uk/itm/T3-TURBO-E...item27ad1a1b41
yeah ,thats the kind of thing , i was hoping for one about 25-30mm thick , i think those T3 to T3 ext flanges maybe a bit thicker than that .
Good advice on asking CR tho ,i'll bell Vince in the morning .
Matt Baxter
Sep 16, 2015 08:30 PM
markk
18
Aug 17, 2015 05:19 AM
Escortdriver1
Aug 5, 2015 12:45 PM
