Aftermarket HID Conversion Kits
Old Oct 24, 2011 | 12:26 PM
12340987's Avatar
12340987
Default Aftermarket HID Conversion Kits
Anyone have any views on these?
Mine turned up today and i only paid £30 for it, looked at the instructions and the wiring and thought. hmm maybe not.
Then thought its £30, sod it, plug obvious wires together, then it said something about drilling a 25mm hole in the back of the headlight bulb access cover
The positive and neg connections had spade connectors on them already but were a loose fit in the dipped headlight plug so i cut them off and fitted bigger amp blue ones and they were then as tight as a nuns fanny !
I basically managed to stuff most the wiring tidily inside the headlight unit, with a gentle bit of pressure i managed to put the backing back on and clip it back on without drilling holes.
They were advertised and bright white, like daylight, but look a bit blue
Ill put some pictures up later.
Its a turbo revs 6000k kit. but for £30 posted, very chuffed
Old Oct 24, 2011 | 12:28 PM
cossie891's Avatar
cossie891
Nice 1 fair play
Old Oct 24, 2011 | 12:38 PM
mechanic28's Avatar
mechanic28
Odds on they aint got no pattern on them these kids are going to be a mot fail soon bud,but at 30 can't complain!!
Old Oct 24, 2011 | 12:41 PM
chaffe's Avatar
chaffe
Turbocharging Technician
bring back tabetha
Old Oct 24, 2011 | 12:54 PM
12340987's Avatar
12340987
Who is tabetha?
Cars got 12 month ticket on it, and will probably end up as beer cans by the time thats up so not fussed and even so its a 5 minute job to revert it back to standard bulbs, ive even kept the standard bulbs in the glovebox incase mr plod decides to be funny about it
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
