FRS Brembo caliper brackets to 2wd Cossie hub - where from?
Old Oct 23, 2011 | 10:02 PM
R4N SS's Avatar
R4N SS
Default FRS Brembo caliper brackets to 2wd Cossie hub - where from?
I need a good quality bracket which can properly fit Focus RS brembo calipers and discs to the 2wd Cosworth hub?
I have a set of brackets that came with the brakes off someone on here but the brackets are shit and causing the calipers to hit the wheel hence needing a decent set of brackets to do the job.
Ran
Old Oct 23, 2011 | 10:11 PM
fraser9764's Avatar
fraser9764
You will struggle with the hocks Ran, i think my wheels are et35 and yours et40, and i had to run a 6mm spacer to get them to clear, making them et29 i believe? im on home made brackets and the wheels just clear the backs of the spokes and the inside of the rim.
i dont think anyone makes them off the shelf, i did ask reyland as they do radial mount brackets but the weren't interested.
Old Oct 24, 2011 | 08:50 AM
R4N SS's Avatar
R4N SS
Ade500 has the same set of wheels on his 3dr and they are ET40 too. Need to ask him what brakes he is using.
Im sure most tuners or garages have done this mod already, the problem is the bottom of the caliper is hitting the inside of the wheel not the spokes.
Old Oct 24, 2011 | 09:14 AM
YOREVOL's Avatar
YOREVOL
YOREVOL
i use bmw brembos with brackets from caprisport and 17"tsw evo r. with no issues. the bmw calliper is bigger than frs.
Old Oct 24, 2011 | 02:44 PM
R4N SS's Avatar
R4N SS
right, i better try caprisport then
cheers
Old Oct 24, 2011 | 02:50 PM
dingla rs's Avatar
dingla rs
you could make these's ur self with drill grinder and some metal
Old Oct 24, 2011 | 03:05 PM
R4N SS's Avatar
R4N SS
i havent done metal work since secondary school and that was only when the teacher's wanted me in their class
i realise its very simple to make but for someone who works on computers all day - i actually want some brackets that fit properly as the ones i was given with the brakes look like a home made job and they certainly fit like one
Old Oct 24, 2011 | 04:49 PM
dingla rs's Avatar
dingla rs
whats the problem with home made items?
Old Oct 24, 2011 | 05:23 PM
mk2rstaff's Avatar
mk2rstaff
What discs are used for this conversion?? Focus RS or just larger aftermarket ones???
Old Oct 24, 2011 | 05:27 PM
dingla rs's Avatar
dingla rs
if for a2wd cossie focus rs discs will fit ,
Old Oct 24, 2011 | 05:42 PM
mk2rstaff's Avatar
mk2rstaff
Thanks Dingla, 3dr cossie no drama then, has anyone done these and put the lenso multi spoke wheels over this conversion, sounds good this
Old Oct 24, 2011 | 05:47 PM
dingla rs's Avatar
dingla rs
they wount fit on a 4x4 cosworth as we tryed hit the track rod end mount
Old Oct 25, 2011 | 11:43 AM
R4N SS's Avatar
R4N SS
they are focus rs discs and the same brembos as found on focus rs's.
the brackets look like they were made by a blind man, the holes for the bolts are too big as when you do an emergency stop the whole caliper moves and hits the wheel
Surely someone has a decent set as its a fairly common conversion and im surprised there arent many people selling ready made brackets for these.
Old Oct 25, 2011 | 12:02 PM
MK MOTORSPORT's Avatar
MK MOTORSPORT
hi there if you send me disc and caliper i will do some
mark
Old Oct 25, 2011 | 01:00 PM
Danielbetty's Avatar
Danielbetty
Hey mate this bloke on here dose them joe150707 £80 posted got them
On mine
Old Oct 25, 2011 | 01:03 PM
R4N SS's Avatar
R4N SS
do you have a contact number?
Old Oct 25, 2011 | 01:45 PM
Danielbetty
Sorry mate no just do a search and pm him that's what I did cheers
Old Oct 25, 2011 | 02:07 PM
gingeRS's Avatar
gingeRS
i wouldnt bother the FRS brakes are pretty poor in my experience.
jason_nike
Aug 18, 2019 10:53 AM
Ford Focus RS Parts for Sale.
Jun 2, 2016 06:46 PM
FlashRS
13
Aug 31, 2015 06:02 PM
RsS2daz
Aug 14, 2015 05:26 AM
lockie
Jul 31, 2015 10:03 PM
