P8 L8 ecu
Old Oct 20, 2011 | 08:53 PM
jimhc's Avatar
jimhc
big jc
Default P8 L8 ecu
whats the diffrence between P8 and L8 ecus can you use the P8 on a 2wd saphire cosworth or is it just L8?
Old Oct 20, 2011 | 11:30 PM
Ad4m RST's Avatar
Ad4m RST
Jiu Boxu
Not sure if the L8 can run anti-lag or 8 injector amongst other things, where the P8 can... stand to be corrected though.
Old Oct 31, 2011 | 10:37 PM
jimhc's Avatar
jimhc
big jc
does anyone else have more info bout the ecu,s
Old Oct 31, 2011 | 10:50 PM
Ima Racing's Avatar
Ima Racing
See msd the l8 can run anything u want!
Old Oct 31, 2011 | 10:51 PM
lukeytheduke's Avatar
lukeytheduke
im sure u can run everything with l8 but with p8 u get things like closed loop for free whereas on l8 u have to pay for it.
But im no expert mate
Old Oct 31, 2011 | 11:24 PM
Rsmat's Avatar
Rsmat
You Can use both on a 2wd... The l8 can also run closed loop.. Anti lagg.. Launch control... MSD are the guys that know how.
Old Nov 1, 2011 | 08:59 AM
martysmartie's Avatar
martysmartie
L8 is simply plug and play with a PF09 aka 4x4 TPS and inverting the wires for it, P8 should be just the same!
So far as I know L8 can do nearly everything the P8 can do, such as Anti lag, launch control, CL, it has 128K memory (Double that of it's predecessors) , in addition WS is native on the P8 and just requires enabling.
Martin
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
griffo69
Oct 4, 2015 11:58 AM
R4N SS
Ford XR Parts For Sale
Sep 15, 2015 03:38 PM
DixieTheKid
Sep 14, 2015 09:04 PM
Tank Mike
Sep 14, 2015 03:56 PM
