cosworth oil breather set up ?
Ideally I dnt wana run one from rocker cover as not much space on a focus Cosworth
So would I need a 2 pipe catch tank? Iv never owned a cossie
Before so new to this
this has always been up for discussion - weather you need to fit a breather to the top of the cam cover or. ive had cosworths with both set ups and both worked perfectly well.
btw im just about to fit a breather to my focus so ill let you know how i get on Andy
Mine breathes from both sides of the block, under the turbo and kidney box and returns to sump below oil level. Mine is a small turbo cam cover so not easy to breathe from the cam cover.
JoeyBoyden
Aug 18, 2015 10:52 PM
Aug 14, 2015 07:29 AM
