Focus RS Brembo's
Old Oct 18, 2011 | 09:10 PM
Sticky.'s Avatar
Sticky.
Default Focus RS Brembo's
Are Focus RS Brembo's the same as Fiat 20v Turbo's?
Or do they just look the same?
Old Oct 20, 2011 | 03:01 PM
Lee-FRS's Avatar
Lee-FRS
I read they are the same on RSOC, bit the fiat's have wire sensors which you just take off to fit FRS.
Old Oct 20, 2011 | 03:53 PM
SteveB's Avatar
SteveB
Pads are defo the same, not 100% sure on the calpiers tho
Old Oct 20, 2011 | 07:15 PM
Sticky.'s Avatar
Sticky.
I checked the 406 coupe ones today Steve like you said in GD, they run the same pads but the 406 pads are 2.5mm thinner.
Old Oct 21, 2011 | 02:02 PM
SteveB's Avatar
SteveB
My Ferodo book at work lists the 406 pad as 0.3mm thinner than the Fiat/Focus pad, which lets be honest you wouldn't notice so seems a waste of time making 2 part numbers.
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
Sp3no
Sep 27, 2015 07:23 PM
Tank Mike
Sep 26, 2015 08:07 AM
