Focus RS Brembo's
Old Oct 18, 2011 | 07:38 PM
Sticky.'s Avatar
Sticky.
Default Focus RS Brembo's
Are Focus RS Brembo calipers the same as the Fiat 20v Turbo's?
Or do they just look the same?
Old Oct 18, 2011 | 08:42 PM
snoopaloopa's Avatar
snoopaloopa
Same
Old Oct 18, 2011 | 08:49 PM
7sean7m7's Avatar
7sean7m7
Are they the same as on any other car too?
Old Oct 19, 2011 | 07:08 AM
SteveB's Avatar
SteveB
Peugeot 406 Coupe as well...
Old Oct 19, 2011 | 03:52 PM
R4N SS's Avatar
R4N SS
evo 8 and 9 brembo 4 pots are way different and much bigger than what is found on the focus
Old Oct 19, 2011 | 06:08 PM
zippyobrien's Avatar
zippyobrien
There not The same. Have different mounting lugs and ofsets. Also I believevthe fiat runs smaller thickness discs.
Old Oct 19, 2011 | 06:42 PM
SteveB's Avatar
SteveB
Late 5's, 6, 7, 8 and 9 are all the same, that's what I have on my Focus
Old Oct 19, 2011 | 06:45 PM
zippyobrien
Also found on the big engined alfas, tvrs, some ferraries.
Old Oct 19, 2011 | 07:00 PM
Rsmat's Avatar
Rsmat
As above 406 coupe.
Old Oct 19, 2011 | 07:10 PM
Sticky.'s Avatar
Sticky.
Are they the same size steve or a bigger caliper that would fit?
Old Oct 19, 2011 | 08:46 PM
dingla rs's Avatar
dingla rs
evo they loads bigger that frs calipers and if for a frs vw pheaton discs can be made to fit ask fella above steve b
Old Oct 20, 2011 | 07:11 AM
SteveB's Avatar
SteveB
I made my own "kit" up using VW Phaeton 360mm x 34mm discs redrilled to 4 x 108, Mitsi Evo calipers and made my own brackets up out of plate alloy.
In the pics you can see the difference in caliper size and pads size.
Took me about 8 hours start to finish to get it all fitted up...
Old Oct 20, 2011 | 08:31 AM
R4N SS's Avatar
R4N SS
Evo Brembo 4 pots are definately way way bigger than Focus RS Brembo 4 pots - even the piston sizes are bigger. I know as i was comparing them directly side by side a couple of days ago.
Focus RS Brembo look tiny compared to the Evo equivalents.
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
Sp3no
Sep 27, 2015 07:23 PM
Tank Mike
Sep 26, 2015 08:07 AM
