siemens 55lb code?
Oct 15, 2011 | 08:03 PM
siemens 55lb code?
hello all,does anyone know the code from siemens 55lb injectors for cosworth ? thanks a lot
Thanasis
Oct 15, 2011 | 08:16 PM
the code on the injectors is 3102. but there must be a part no for them somewere as i tried to get a price on them the other day with the 3102 no and thay said it wasent long enuff for the part no. so im hopein some one knows it lol
Oct 15, 2011 | 08:19 PM
one guy sell these 55lb injectors with code 3172 so what the difference? thanks
Oct 15, 2011 | 08:23 PM
Oct 15, 2011 | 08:24 PM
Quote:
Originally Posted by
Thanasis
thay should have 3102 on them if not then thay are not 55lb injectors thay might be a lower or higher flow mate
Oct 15, 2011 | 08:25 PM
I'd also be interested in this info, as i'd like to get some 55lb siemens for a decent price.
Oct 15, 2011 | 08:26 PM
escoskmv
thank you mate
Oct 15, 2011 | 08:33 PM
Oct 15, 2011 | 08:41 PM
Tony Mannock
I think you'll find these injectors are £250 a set including vat from matt lewis or msd
i know that mate,thank you, but here one guy sell used 55lb with 3172 code,for that reason i asked here if these are the same as msd or matt lewis,but finally are with high ohm so does not work on cossie, thank you
Oct 15, 2011 | 09:41 PM
3102 is 55lbs, however you might see f111402.
55lbs are 575cc/min part number: 3102
72lbs are 750cc/min part number: 3145
83lbs are 865cc/min part number: 3105
Oct 16, 2011 | 12:33 PM
So the low ohm one,s are the type to use on the MSD 380 BHP chip upgrade? For P8 ecu.
Nov 1, 2015 06:53 PM
timsrs
22
Sep 24, 2015 08:14 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Digispurs
Ford Focus Range
Sep 16, 2015 09:47 PM
