what's the worst job youv'e done on your car
Old Oct 15, 2011 | 05:26 PM
Turbosimpsons's Avatar
Turbosimpsons
Default what's the worst job youv'e done on your car
mine was getting every bit of paint off my escoz front bumper because i don't like seeing primer showing through when there is paint chips.
Old Oct 15, 2011 | 05:37 PM
zetec-Sam's Avatar
zetec-Sam
neeeeeeeeooowmmmm
Rear beam bushes in my fiesta with no press. Cunt-ache!
Old Oct 15, 2011 | 05:38 PM
gus's Avatar
gus
changing oil filter on my old ranger
you canonly just get to it and when you get it off you have nowhere to go with it
took me longer to clean up the mess then it did to service the truck
Old Oct 15, 2011 | 05:48 PM
boothy's Avatar
boothy
Bought that stupid rs turbo i have!
Old Oct 15, 2011 | 05:49 PM
Chaz888's Avatar
Chaz888
lower control arms on the coog after fitting the st engine ,had to find a way to compress the stut and get the lower ball joint pin back in ,was a real shit and took too much time but got there in the end .
Old Oct 15, 2011 | 06:08 PM
JonnyBravo's Avatar
JonnyBravo
Starting a resto job on mine
Old Oct 15, 2011 | 06:10 PM
Sonic Boom's Avatar
Sonic Boom
The Hart Inlet on my 3 Door and taking my T66 turbo on and off.
Rich
Old Oct 15, 2011 | 06:11 PM
dave cos4x4's Avatar
dave cos4x4
exhaust manifold off.
Old Oct 15, 2011 | 06:17 PM
bubs_rsturbo's Avatar
bubs_rsturbo
hahaha! yes +1 i also have a stupid rs turbo i seriously feel like setting a match to!
Old Oct 15, 2011 | 06:32 PM
rs clint's Avatar
rs clint
insane
changing gearbox and clutch no ramps just jacks axle stands
Old Oct 15, 2011 | 06:48 PM
GINGExR2 T's Avatar
GINGExR2 T
RWD my S2 ERST, still doing it, does my box in
Ginger
Old Oct 15, 2011 | 07:48 PM
BRAMMER's Avatar
BRAMMER
I'll second that, just fitted mine up to my new motor out of the car which made it easier but i made the mistake of fitting longer studs and the 3 centre lower studs are a complete cunt to do when off so in the car would be a right cunt
Old Oct 15, 2011 | 07:52 PM
juffer's Avatar
juffer
CVH sump gasket
Old Oct 15, 2011 | 08:27 PM
dojj's Avatar
dojj
Resident Wrestling Legend
air con pump on the mondeo, 8 months
Old Oct 15, 2011 | 08:35 PM
LukeDaisley's Avatar
LukeDaisley
mk6 fiesta heater controls. If you have refitted one you will know.
Old Oct 15, 2011 | 09:25 PM
Turbosimpsons
wow 8 months. thats some job.
Old Oct 15, 2011 | 09:29 PM
RichieST's Avatar
RichieST
Yup, they are a fucker! I remember they've got a rod thing that disappears into the dash and you can only get it in one end or the other, not both at the same time when putting the panel back on. Must have taken me about 2 hours!
Old Oct 15, 2011 | 09:44 PM
andy130's Avatar
andy130
what did you use on the bumper mate?
Old Oct 15, 2011 | 09:59 PM
dojj's Avatar
dojj
i gave up as it was such a bitch to get to
eventually i stripped down the whole front end to get the bastard out which took a day to do out and then 30 seconds to change the circlip and then another day to put back together again
Old Oct 15, 2011 | 10:00 PM
t16coupe's Avatar
t16coupe
starter motor and knock sensor on my pulsar gtir
Turbosimpsons
believe it or not, i tried loads of things. i ended up buzzing most of it off with an orbital sander, then sandblasting the hard to get bits.(on low pressure) was a right ball ache. worth it as i can now prime it with clear plastic primer then mallard on top. when the bumper gets stone chips it won't stick out like a sore thumb.
Old Oct 15, 2011 | 10:10 PM
leo_cos's Avatar
leo_cos
why not just use 3m black 2k primer??
Old Oct 15, 2011 | 10:11 PM
Joshy's Avatar
Joshy
Dreamer
could you not have got some of that stone sheild plastic film stuff?
Old Oct 15, 2011 | 10:18 PM
andy130's Avatar
andy130
yeah would you not need 2k primer on it after plastic? looks good by the way
Old Oct 16, 2011 | 04:38 AM
mk2rstaff's Avatar
mk2rstaff
Would have to be cutting the rear windows out of my 3dr cossie with shit stanley blades took me a few days on and off lol, was trying not to damage the paint and at the end it suddenly dawned on me i was cutting them out for it to be painted, what a fekin plum lol
Old Oct 16, 2011 | 08:32 AM
Adam.'s Avatar
Adam.
Needs Beer Tokens.....
Starter motor, new shape honda civic.......what a cock!.
Old Oct 16, 2011 | 08:44 AM
yellowsierra's Avatar
yellowsierra
giving my car to someone else to do a good few years ago
Old Oct 16, 2011 | 08:56 AM
STeve's Avatar
Super Moderator
heater matrix on a saph
Old Oct 16, 2011 | 09:23 AM
chaffe's Avatar
chaffe
Turbocharging Technician
Doing the clutch on my old pulsar gti-r, engine and box out job! no ramp either in a tight single garage
Old Oct 16, 2011 | 09:25 AM
ozmk1cos's Avatar
ozmk1cos
Clutch on a 89 patrol. Gearbox weighing a couple of hundred kilo
Old Oct 16, 2011 | 09:38 AM
James's Avatar
James
the O ring that goes between the front diff and sump on a xr4x4, grrrrr!
mk3 golf rear axle bushes too !
Old Oct 16, 2011 | 10:07 AM
Saff cossie 4x4 bottom suspension arms on the front.Getting the bolt to line that holds the arm onto the sub frame is a bastard.
Someone said use a ratchet strap to pull the anti roll bars across so that they will line.
Old Oct 16, 2011 | 10:56 AM
stu21t's Avatar
stu21t
Core plugs on e36 m3 evo
I bought a cabrio in october 1 year, when the tax ran out at the end of the month i parked it up cos i had a hard top too.
When I came to use it in summer i checked oil, water....
Water was low so i topped it up. As i poured it in on pass side, it ran out on drivers side
Turns out there was no antifreeze and over winter it froze and popped a core plug out the block.
On an m3 they are under the exhaust fanny mould which you cant remove in the car. An absolute cunt of a job to do, i even cut the claw off a hammer to get more "swing" lol.
Not something i will rush to do again!
Old Oct 16, 2011 | 11:24 AM
Graceland's Avatar
Graceland
Team HOTHOT!
Changing the steering box on my E39, hardly any room to work and it weighs a ton
Incidentally, it was far easier to convert the car from automatic to 6 speed manual
Old Oct 16, 2011 | 11:35 AM
Turbosimpsons
my front bumper had already had paint and someone had used grey primer. you'd also be surprised how much better the lines show up when there is less paint on it.
Old Oct 16, 2011 | 11:37 AM
dojj's Avatar
dojj
tell me about it, i go someone to do it for me for £70 odd
yes, they will do but you should have both wheels off the ground first and then simply pull the hubs into line and the bush will go back in again
you need one of them 10 ton straps to be really sure though, but i used several miles of thick nylon rope tied around the struts and everything and then simply sound them in with a big bit of metal
Old Oct 16, 2011 | 12:28 PM
mk1trb's Avatar
mk1trb
Boost Junkie
hte doing clutches and boxes on my back and thwey always seem to go on me in the cold aswel which makes it even worse
Old Oct 16, 2011 | 06:56 PM
12340987's Avatar
12340987
lowering the back of a focus mk1, bolts sieze into bushes, snap, new wishbone - £30 - £40 and the cutting out of bolts, no space for spring clamps and limited movement
The Underdog
29
Sep 7, 2015 09:49 PM
pegaz
11
Aug 9, 2015 06:40 PM
vdubo7
Aug 2, 2015 08:17 PM
hazbaz1984
Ford Focus (All Models)
Jul 30, 2015 05:15 PM
