Big brakes for sapphire????
Old Oct 11, 2011 | 08:58 PM
PHILMC1978's Avatar
PHILMC1978
Default Big brakes for sapphire????
WHAT RECOMMENDATIONS HAS ANYONE GOT FOR A 4X4 SAPPHIRE FOR BRAKE UPGRADES? I WILL BE RUNNING 400 BHP ISH, AFTER RUNNING IN, HOPEFULLY! WASTED SPARK, T34.63, BD14'S, SIEMENS 55'S, AP 6 PADDLE, PRO ALLOY INT AND FANS, BOSCH 044, WORKS CARRIED OUT BY JAMES @ MSD, TOP GUY!
Old Oct 11, 2011 | 09:07 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
has to be ap,s i went cheep to begin with had a comp brake 330 set up they would fade out so fast put ap,s on and they are miles better never faded iver plus there has been some cheap sets go on here if you dont mind second hand!
Old Oct 11, 2011 | 09:10 PM
PHILMC1978's Avatar
PHILMC1978
Thanks for quick reply, i do have a brand new set of ap 4 pots ( says TVR on the side of em ), does anyone know if the fit without TOOO much trouble?
Old Oct 11, 2011 | 09:13 PM
ajamesc's Avatar
ajamesc
i guess you would have to get the model number of the calipers then ask someone like rayland to make up some brakets do the discs have separate bells as you would need them to
Old Oct 11, 2011 | 09:19 PM
PHILMC1978's Avatar
PHILMC1978
WILL HAVE A LOOK AT THEM TOMORROW AND POST A PIC ON HERE, CHEERS MATE.
Old Oct 12, 2011 | 05:52 PM
dazzle740's Avatar
dazzle740
yeah AP's mate with 330mm discs awesome power!!! I also running about 400 ish never had a problem stopping.
Old Oct 13, 2011 | 06:58 PM
Matt Lewis's Avatar
Matt Lewis
RS & ST Parts Specialists
my opinion would be also to go for APs
Old Oct 13, 2011 | 08:55 PM
PHILMC1978's Avatar
PHILMC1978
I do have a pair of new AP CP5200 4 POTS, where is best to source brackets, bells, discs etc?
Many thanks for the 4x4 stat and gp A air filter via Ebay, stat was a godsend after lots of headscratching with 'odd overheating' problem i had. Tony at TURBOSYSTEMS recommended yourself.......
Old Oct 13, 2011 | 09:12 PM
Paul_RS's Avatar
Paul_RS
Reyland will have those parts on the shelf more than likely. I've CP5200s on my car and love them. Go for Ferodo DS 2500 pads too
Old Oct 13, 2011 | 09:21 PM
PHILMC1978's Avatar
PHILMC1978
Thanks Paul, will also need new wheels as well as i believe?! On RS7's at the moment.
I do have a small problem with my brakes at present.... on first applying the footbrake the pedal seems to push back up against my foot and resist pressure and then makes a ' clicking noise/feel' and goes back down, any ideas? ABS fault? No lights on dash showing though.
Old Oct 14, 2011 | 11:28 AM
R4N SS's Avatar
R4N SS
relay fucked?
Old Nov 3, 2011 | 06:59 PM
PHILMC1978's Avatar
PHILMC1978
Originally Posted by R4N S S
relay fucked?
Will give it a try and keep you posted, many thanks
Old Nov 3, 2011 | 07:12 PM
martysmartie's Avatar
martysmartie
If the pedal is pushing back then the ABS is active, does it happen when stopping at very slow speed, i.e. when crawling to a junction, or just applying the brakes, period?
Martin
Old Nov 3, 2011 | 08:33 PM
James @ M Developments.'s Avatar
Its the ABS kicking in phil, First thing i would check is the ABS rings are clean, and test the wheel sensors are working correctly,
i think the system is assuming one of the wheels has stopped rotating when you start to slow down, hence firing the abs, when the wheel hasn't actually stopped at all.
Old Nov 3, 2011 | 08:35 PM
PHILMC1978's Avatar
PHILMC1978
Martin
I think it does it when stopping at slow speed, can't remember as i haven't drove the cash drainer for a little while! Pretty sure though!
Old Nov 3, 2011 | 08:38 PM
PHILMC1978's Avatar
PHILMC1978
Hi James, thanks for the input, will check everything out next week... cheers bud
Old Nov 3, 2011 | 08:39 PM
i have the ford ABS manual for these, feel free to pop in to have a look and read if you like.
Old Nov 3, 2011 | 08:46 PM
PHILMC1978's Avatar
PHILMC1978
Thanks James, i feel like i spend more time there than at home! The joys of cosworth ownership i guess.... i will pop in next week, als and launch control next and then a new gearbox!
Old Nov 3, 2011 | 08:47 PM
Old Nov 5, 2011 | 10:47 AM
charlie luciano's Avatar
charlie luciano
Some of these
Luciano
Old Nov 5, 2011 | 02:42 PM
PHILMC1978's Avatar
PHILMC1978
Originally Posted by charlie luciano
Some of these
Luciano
Looks well, what size etc? Where from? Many thanks
Old Nov 5, 2011 | 07:05 PM
charlie luciano
TBH my tuner supplied and fitted them so I have no idea where he got them from
they are 330mm discs and 4 pot calipers I would try someone like Mike Rainbird
Luciano
Old Nov 7, 2011 | 05:30 PM
v man's Avatar
v man
Zee Germans are coming
i recommend martin at reyland
he supplyed me with my ap's discs brackets and bells all bolts and washers etc
and he was a good price to
and the bells and brackets came anodised in a colour of my choice and the bells had reyland engraved in them
Old Nov 20, 2011 | 08:53 AM
carls9941's Avatar
carls9941
I have a 4x4. And I got 335mm hi spec with 6pot calipers. They all work well and look good doing the rears aswell real soon
Old Nov 20, 2011 | 12:24 PM
kaisersolsay's Avatar
kaisersolsay
Give Hi Spec a look. I've got 380mm 6 pots on mine and really fit up the inner 18" Compo's.
Old Nov 20, 2011 | 04:08 PM
BIL N KEL's Avatar
BIL N KEL
Is it true 330 ap's won't fit under rs7 spokes? If so what brakes will fit?
155lee
Oct 27, 2015 04:55 AM
tib2220
Sep 14, 2015 12:33 PM
The Enigma
Sep 12, 2015 10:12 PM
focus2351
Sep 9, 2015 09:33 PM
