Low Compression turbo conversion
Old Oct 10, 2011 | 03:33 PM
Focus333's Avatar
Focus333
Default Low Compression turbo conversion
Rightt bringing up an old topic. Earlya this year put some piper cams on my 1.8 zetec, along with a 2.0 turbo head, runs 100% perfect but as you can see, running low compression (didnt think of that at the time).
Anyways I want to make the most out my cams and see 2 options:
1- swap the 1.8 block for a 2.0 block, skim the head and make it high compression, then go the route of throttle bodies or something.
2- make the most from the low compression and turbo it, as the way i see it besides maybe some stronger valve springs, its capiable of a turbo now.
Needs some help on this from experts unlike myself
Old Oct 12, 2011 | 07:34 PM
forevaford's Avatar
forevaford
that compression wont be low enouph for anything above 6 psi with standard pistons in my opinion
Old Oct 12, 2011 | 08:32 PM
hogdog's Avatar
hogdog
I'm confused, what head is it? A standard 2.0 head will drop the compression very slightly on the 1.8 but not much.
Alot of people run decent power using standard pistons and ARP con rod bolts.
Old Oct 13, 2011 | 07:49 PM
Churtz's Avatar
Churtz
Agreed! The head won't really change the compression much...it will just be ported differently to a NA head.
Matt
Matt Baxter
Sep 16, 2015 08:30 PM
yatta
Sep 1, 2015 11:28 AM
A.t.p
Aug 15, 2015 11:37 AM
155lee
Aug 14, 2015 11:21 AM
Zoggon
Aug 10, 2015 10:39 AM
