T3 flange turbo specs
Old Oct 9, 2011 | 10:31 PM
Ade's Avatar
Ade
Fast Ford snapper
Default T3 flange turbo specs
I've also got an Alfa Romeo 155 Cloverleaf 4, which incidentally shat its turbo at the Ring today.....
Looking for info on what turbo to get, and a little upgrade would be nice. The Alfa forums aren't the best for info as so few of the cars were made!
It seems to run a Garrett tb0367. As well as the Alfa 155 Q4 its listed as standard fitment on the Delta Integrale Evo and Fiat Coupe as they have near identical engines.
Anyone know the actual specs of this turbo so I can compare against the others?
Thinking of:
Escort RST
Cossie 2WD
Cossie 4x4
Escos T34
etc....
Some background....
Can't really do over 300BHP on a standard bottom end on there (well so they experts say!). 190BHP standard, and running the usual chip at approx 1BAR they are meant to make 235BHP with the standard breathing.
Got a 3" pipe and decat on mine with a decent induction too. Feels like at least 250BHP anyway on the standard turbo.
4 bolt downpipe flange, but I'm hoping the elbow could be swapped easily enough?
Old Oct 10, 2011 | 08:13 AM
Ade's Avatar
Ade
Fast Ford snapper
Anyone?
Old Oct 10, 2011 | 12:06 PM
wilky's Avatar
wilky
looks like the normal t3 ,get hold of a cossy 4x4 unit you may have to use you exhaust housing as i think there there is a bit of clearance cast in the snail for your actuator rod[iam sure of it ]
Old Oct 10, 2011 | 02:26 PM
Ade's Avatar
Ade
Fast Ford snapper
Won't really be able to use much more than the elbow from my turbo as I'm having to drive it a good few hundred miles home with the oil feed disconnected! Sure it'll all be fucked by then!
Ford Focus RS Parts for Sale.
Jun 2, 2016 06:46 PM
Oct 9, 2015 07:38 PM
Matt Baxter
Sep 16, 2015 08:30 PM
mint_s2
Sep 2, 2015 08:58 AM
IAN RS2k
Aug 18, 2015 07:51 PM
