02 plate tdci, jumpy on clutch
Ł400 is cheap!!!
i would get that in writting or budget for a few ŁŁŁ more, cost me nearly Ł700 with a 3 piece clutch,DMF,rear crank seal and the exhaust that got fooked up from dropping the subframe and exhaust falling apart lol
And if youre getting this done, get the crank seal replace like i did, it'll cost about Ł5 and save you taking half the car apart when it starts to weep and fook up the new clutch.
I wouldnt go there even if they were doing it for free. My wife took her Subaru Legacy there .Dual mass clutch was replaced. The car was taken for a checkup at our usual garage, about 3 weeks later to look at a vibration issue . One engine bolt was found to be missing and another was about to fall out. Also, the nearside front wheel retaining nut on the end of the driveshaft was loose as the locking tab had not been refitted properly. This resulted in the replacement of the driveshaft as wear and damage had occurred due to everything flapping around. Their name stinks in the motor trade. So make up your own mind. I think the old saying, you get what you pay for rings very true in most cases.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
The Enigma
Sep 29, 2015 10:31 AM
