saff cossie 4x4 track control arm bushes
Are the tca bushes that hold the arms onto the roll bar for the sierras all the same.Im after the heavy duty bushes not the cheapo ones.
Ive had a look on ebay and there seems to be loads of these bushes for sale for all different size engines in the sierras.
no matter the price, they are well worth it
the outer tca bushes are the same size across the range
the inner ones are normally 10mm but on some xr's and all cossies they are 12mm
the biggest variation is in the arb to body bushes as they range from 24 to 26 to 28 to 29mm
Cheers Dojj you know your stuff.
Or Thank Rax.Fingers crossed you can find them.Im fitting konis to the car over the winter so will get these bushes done too.
155lee
Sep 14, 2015 07:37 PM
Anutternutter
Aug 21, 2015 06:07 PM
155lee
Aug 14, 2015 11:21 AM
RIB1122
Aug 12, 2015 08:49 PM
