focus 1.4 petrol mark 1
gauge stay midway when idling but goes into red fairly quickly when accelerating, as soon as you take foot off goes back to midway. Had newThermostat, sensor, radiator flushed and new coolant added. Only able to drive by keep taking foot off accelerator. Onboard diagnostics show temp of 104 when gauge midway and 124 when in red.
Could well be water pump on its way out or a blockage somewhere in the cooling system. Has it ever been run with just water in it? I'd try flushing the engine and radiator through then refilling with coolant, if that doesn't work then I'd be looking at the water pump.
Thanks for your reply. Radiator has been flushed through and coolant replaced but probably engine not flushed. What is the difference with it being run just with water??? Water pump looks new. Having new exhaust fitted today and am wondering if it could be blocked catalytic converter.
Antifreeze has a rust inhibitor in it, so if you run it with just water then you will get rust building up inside the water ways which will eventually cause a blockage in the system. I don't think it will be the cat, you will just notice a loss in power if that fails. It could also be worth changing the temperature sensor, it sits between number 2 and 3 spark plug. Check the wiring to it too for damage / breaks.
I'd also get the car up to normal running temperature then remove the radiator cap CAREFULLY, put a towel over the cap and release very slowly. Look in the tank and if there is a steady stream of bubbles coming up through, then i'd be looking at a head gasket issue.
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 3, 2015 04:08 PM
