mahle pistons
Old Sep 27, 2011 | 08:27 PM
ethan89's Avatar
ethan89
frst
Default mahle pistons
hi guys does anyone no what boost the standard pistons and rods will take before having to be forged?
Old Oct 5, 2011 | 07:41 PM
duk2's Avatar
duk2
totally std 7psi
stage 1 chip 165, 10-12psi
stage 2 chip 195, 15-17psi
but wouldnt expect the bottom end 2 last that long on 17psi if is done alot of miles!
hope this helps mate
Old Oct 18, 2011 | 10:09 AM
Rogeyboy's Avatar
Rogeyboy
Stock bottom end is good for 220-240bhp, alot of people run around 240-250 reliably with no probs... Id cap boost at 20psi as a max tbh!
Old Jan 2, 2012 | 04:06 PM
mk1trb's Avatar
mk1trb
Boost Junkie
been known for a few on standard pistons to get over 300bhp but havent lasted long
Old Jan 11, 2012 | 06:57 PM
Brendan's Avatar
Brendan
struggling with reality
je forged pistons work for me!
Old Feb 12, 2012 | 12:40 PM
daveb_lives's Avatar
daveb_lives
mine runs 196 brake on standard pistons with 18psi boost, and has dont for about 12k miles.
dave
Old Mar 2, 2012 | 09:24 AM
essexRSTSouthend's Avatar
essexRSTSouthend
These one's running 300 bhp i suspect they are running forged conrods with standard pistons?
People use standard bottom and abused on track in the 270bhp area. Depends how much risk you want to take. I'd personally stick to max of 250bhp and then get that bottom sorted.
Old Mar 4, 2012 | 11:30 AM
Ben26's Avatar
Ben26
It's the rpm that will kill the rods mate. Friend of mine ran 26+ psi with only arp rod bolts and thrashed it all day long for years with no problems. Luck of the draw I say.
Old Mar 4, 2012 | 08:09 PM
PAULDOLMAN's Avatar
PAULDOLMAN
i think it's got a lot to do with the management system your using, if you upgrade to a weber(cossie management) system the engine can be set up a lot better and you'll get more power and be able to run more boost and that it'll be RELIABLE, mine runs 19psi on a standerd bottom end, and has been running that for years with no problem at all but i know of cars running 24psi with no issues but these are all on weber managed systems
Nov 1, 2015 06:53 PM
little bram
Oct 4, 2015 12:13 AM
deathrider666
Sep 28, 2015 06:12 PM
timsrs
22
Sep 24, 2015 08:14 PM
ajamesc
Sep 8, 2015 06:51 PM
