Towing Rules?
Old Sep 21, 2011 | 05:13 PM
ryan72's Avatar
ryan72
Default Towing Rules?
Just been on DVLA website to try figure out towing rules, and now im confused even more!!
Basically, I past my test after 1997.
The car is a Ford Focus TDCI on a 03 plate.
Im looking to tow a flatbed trailer and a car.
Can I tow this legally, or do I have to do a trailer licence?
Old Sep 21, 2011 | 05:14 PM
Minirotty's Avatar
Minirotty
Lucifer II - 666
afaik you have to do a test because of when you passed.
Old Sep 21, 2011 | 05:19 PM
Fil's Avatar
Fil
ELASTIC BAND
Yep course and test, about Ł500 when i looked into doing it, never bothered tho
Old Sep 21, 2011 | 05:20 PM
saph4be's Avatar
saph4be
possibly not mate search on here loads off threads about it
kev 3dr's Avatar
kev 3dr
Trailer licence and prob over weight towing with a focus anyway mate
Old Sep 21, 2011 | 05:24 PM
rs-tuner's Avatar
rs-tuner
good thread about towing here
https://passionford.com/forum/genera...7-license.html
Old Sep 21, 2011 | 05:40 PM
phil_focus's Avatar
phil_focus
on a post 97 liscence you can drive a car of 3,500kg MAM towing a trailer upto 750kg MAM
OR
you can tow a trailer with a MAM greater than 750kg so long as the combined train MAM does not exceed 3,500kg.
even if you are within these limits you can NOT exceed the towing capacity of the tow vehicle!!!!!!!!!! so you can't tow a focus on a trailer with a micra to keep within the licence weight limits.
to exceed the above you need to take a towing test and have the entiltement added on your licence.
thats the easy bit.
now you need to know what car your going to tow, on what SUITIBLE trailer and get the MAM figure of the trailer plate. if this exceeds the towing capacity of the focus you intend to tow with (even if you don't load the trailer to its MAM) then its illegal even if it falls within the 3,500kg train MAM rule which i suspect it won't!
and all this is before you've checked the trailer is in good working order, including the lights, fitted with the number plate of the tow vehicle and hooked up.
Old Sep 21, 2011 | 06:07 PM
focusv8's Avatar
focusv8
With or without trailer licence, The basic rule is, you can't legally tow a car on a trailer with a car,or a van up to and including SWB Transit size.
Old Sep 21, 2011 | 06:34 PM
rs-tuner's Avatar
rs-tuner
That's wrong as it all depends on the weight of the trailer and car to be towed.
Old Sep 21, 2011 | 06:39 PM
Mark_'s Avatar
Mark_
you can tow a trailer upto 750kg so a car trailer plus car will be over that easily so you will need to do a test
Old Sep 21, 2011 | 06:56 PM
focusv8's Avatar
focusv8
It's 99% correct, Ive tried to simplify it.
The exceptions would be a large or 4x4 car with high towing weight limit using a lightweight trailer to carry a stripped out car, track car or very small car.
Old Sep 21, 2011 | 07:26 PM
JonnyBravo's Avatar
JonnyBravo
I had this discussion with someone the other day, we were using a Lexus RX300 towing a large Brian James trailer with a 1300kg car on and I wasn't convinced it was within the rules or not.
Old Sep 21, 2011 | 08:33 PM
focusv8's Avatar
focusv8
Rx300 (not a car) can tow 2000kg
Brian James trailer, typical load limit 1400kg, total weight 2000kg ish.
You were probably just legal.
Old Sep 21, 2011 | 09:34 PM
markk's Avatar
markk
there are a few exceptions to that rule, see Land Rover/Range Rover and a few other large 4x4's
Old Sep 21, 2011 | 09:42 PM
botters's Avatar
botters
competant bodger
correct some land rovers have a permissable train weight of over 7000kgs
Old Sep 21, 2011 | 09:50 PM
steveboyslim's Avatar
steveboyslim
Default Towing
Everyone at the RSOC National Day using a Transit sport as a tow vehicle and there was lot of them, was breaking the towing law.
Steve
Old Sep 21, 2011 | 10:35 PM
Psycho Warren's Avatar
Psycho Warren
Carbon Crazy
get the trailor down plated to help stay within the limits. most trailor companies will do that for you.
Old Sep 21, 2011 | 10:45 PM
phil_focus's Avatar
phil_focus
there not exceptions to the rule as they ARE rated to tow that much. i don't know about the new stuff but certainly the old discovery's have a towing capacity of 3,500kg. i think your getting confused between towing capacity (what that vehicle is rated to tow) and kerb weight/MAM of just the tow vehicle as, using the example above, the disco's curb weight is around 2,000kg.
Old Sep 22, 2011 | 05:17 AM
chaffe's Avatar
chaffe
Turbocharging Technician
I phoned the police and they didnt know either
Old Sep 22, 2011 | 05:54 AM
Fordmad!'s Avatar
Fordmad!
If its after 1997 don't pull a car trailer!
Don't tow over 750kg
Is baisically the rule!
Old Sep 22, 2011 | 08:55 AM
mcst's Avatar
mcst
A lot of misinformation as usual!
As 1 person has said and got right, provided the MAM of the vehicle and what its towing do not exceed 3500kgs and the weight of the trailer doesn't exceed the limits of the car - its legal for post 97 licence holders to tow.
The 750kg limit is the maximum weight allowed for an unbraked trailer for anyone.
Best options for us with these licences if you don't want to do the test is to run a disco/d90/rangie or similar. They can tow 3500kgs and there's a few light single axle car trailers available allowing you around 1100kgs for a small car.
IIRC the old Kia Sorrento could tow over 2000kgs too as a cheaper alternative to a land rover product!
Heres the definitions for the categories - See Cat B:
http://www.direct.gov.uk/en/Motoring...ons/DG_4022547
If you intend to tow regularly and to remove all doubt its sensible to do your test, shopping around you can get it for between Ł4-600.
Also get yourself to a weighbridge and make sure you know 100% that you're within weight if you aren't doing the test. VOSA are sharp on towing limits, i may have posted it on here before but they recently setup shop outside a country show at Hickstead and checked all the weights etc... of traders and horse types.
Old Sep 22, 2011 | 10:04 PM
bunnymofo's Avatar
bunnymofo
yep, disco series 1 can tow 4000kg with asisted brakes, 3500kg with overrun brakes.
Old Sep 22, 2011 | 10:06 PM
bunnymofo's Avatar
bunnymofo
i bet they cought a good few........
Old Sep 22, 2011 | 10:40 PM
mcst's Avatar
mcst
Yep, mostly traders running double cabs and a box trailer for being over weights or not running a tacho.
Maybe a bit of chinese whispers but apparently they were pinning a few for driving hours too. Something like these horse types running a rangie and loaded horsebox and having worked all week then driving 7 hours to or from the show.
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
Cos500
Sep 16, 2015 09:50 PM
CrOwSoN15
Sep 10, 2015 07:33 PM
