Sierra Ghia 4x4 Dohc Breaking
It's not getting finished and if not sold it's getting scrapped.
Located in Stockton on tees, can get some stuff to Retford area.
Dark grey saff cossie front and rear seats. Good condition. SOLD
Dohc 4x4 mt75 gearbox £100
Dohc 4x4 engine mount arms £15
Xr4x4 LSD complete rear axle. £ SOLD
24v Granada cossie front arb.£30
Rs option deep side skirts. With mounting rails.£40
Saff cossie front and rear bumpers. Ok, end mount on front broken and no fog lights.£80
Granada 5 stud hubs and rear drive flanges. £70
Reconditioned Granada cossie 16" wheels x4 3 good tyres 205/50/16 £40
Saff cossie boot spoiler. Sold
Saff 4x4 ghia shell in black, been stood 4 years+ GETTING CUT UP
24v converted sierra clocks, 24v rev counter fitted. Sold
Can post some items at cost.
would those clocks fit my 1.6 classic sierra? 1989?
if ya have the brake fluid cap ( with sensor ) i'll have that
can ya post also?
if ya can find out about the clocks also i'll take both if they fit
can ya post also?
The Ghia one? If so yes but it has a cut above one of the fog lights
Front or rear?
Clock will fit yes but the rev counter is for a V6 not 4 pot
I'll look for the sensor.
And yes it is a shame. Not bad shell as it is fine for a track car, but person i got it from had washed it with a brillo pad by the looks.
Front or rear?
Bumper photo, cut runs under to the left of the foglight in the pic
Found an electric sunroof motor. From a Granada, I believe then can be made to fit the sierra. £30.
Also forgot its an air con version. If anyone is after bits.
The section the clock goes in with the warings lights?
Paint is not too bad but dull. Driver door needs repairing as i got it to replace one that was on, new one had the lock area bent. Sills have been repaired innner and outer (not painted)
Shell can come almost complete, what do you want ?(included for free are any spiders and webs) :0)
Sounds good, lol. Well all the glass and loom would be good also all panels like boot and bonnet, also front suspension bits to keep the front rolling. I have a spare axle for it so that's that bit sorted.
Basically anything You want to get rid of I'll have it. What you saying price wise?
And if Dojj doesn't want the clock set with 24v rev counter, I'll take it. Can collect.
May also be interested in the recaros depending on how good they are. If I come down for the clock set will take a look at the same time.
cheers
cheers
Shell now getting scrapped in a weeks time.
Anyone after any switches, plastic bits etc let me know. Its a 90 spec so has the later trim and other parts.
Ford Radio, cassette, CD palyers and amp available. with all cables
Did you come across the sensor on the crossmember?
