2010 focus ESP
How the fuck do you turn it off and keep the fooker off...
I know how to turn it off, but when you start the cunt again its on.
in the dry its fine, but in the wet the back wheel braking is doing my twat in
don't drive it so hard in the wet then
you could probably pull a fuse to dissable it but that will put a light on the dash and will probably disable the abs which wouldn't be a good idea in the wet.
wowk
Mar 30, 2021 07:49 PM
