fusion help please
Old Sep 19, 2011 | 05:42 PM
jamesst24's Avatar
jamesst24
ITS ALL GOOD
Default fusion help please
hi all was driving home from work today and my fusion 1.4 zetec se just cut out. Dont do it when its cold just when its warm. When you come up to traffic lights or round abouts when you go to stop it stalls
Please help.
Old Sep 20, 2011 | 03:37 AM
B19 JUB's Avatar
B19 JUB
sounds like throttle body problem tbh fella.depends on year though as early ones just had a throttle body issue,later ones it was the tps and injector loom issue,worth getting checked
Old Sep 20, 2011 | 06:29 AM
jamesst24's Avatar
jamesst24
ITS ALL GOOD
its a 52 plate.
Old Sep 20, 2011 | 12:17 PM
B19 JUB's Avatar
B19 JUB
i reckon its the throttle body playing up but ideally needs checking for fault codes.there was also a software issue which caused cutting out.just a download cured it
Old Sep 20, 2011 | 12:26 PM
martysmartie's Avatar
martysmartie
Idle control fault, could be a few things, namely, ISCV, VSS (Accompanied by a dicky speedo, least likely) or an air leak.
Martin
deathrider666
Sep 28, 2015 06:12 PM
Paddy
Sep 20, 2005 09:02 AM
joe_totalmods
Jun 9, 2005 04:36 AM
POPEYE
16
Aug 31, 2004 07:00 PM
