2wd rear beam help!!!
Old Sep 19, 2011 | 12:03 PM
leo_cos's Avatar
leo_cos
Default 2wd rear beam help!!!
Hi i have a 2wd sierra and currently doin an under side resto on iv hear alot of diffrent storys about bushes and bearings for the rear beam can any 1 tell me wats best to go for or is it better to go with a 6 degree if so where is the best place to get 1 and wat sort of cost are they? The car will be used on the road with the odd track day here and there. Cheers
Old Sep 19, 2011 | 12:15 PM
martysmartie's Avatar
martysmartie
Adrenaline sell them as does Ahmed Bayjoo, imo there are very expensive for what they are. Just replacing tired bushes, poly diff mount etc will make a difference.
Martin
Old Sep 19, 2011 | 12:25 PM
leo_cos's Avatar
leo_cos
Is there much diffrence in price with a 6degree compaird to the cost of powder coating and ggr trailing arm bushes and poly beam mounts? Cheers
Old Sep 19, 2011 | 12:32 PM
martysmartie
Think a 6 degree is around £1k, so yes!
Martin
Old Sep 19, 2011 | 01:35 PM
leo_cos's Avatar
leo_cos
Wat would the best bushes be to use then? Cheers
Old Sep 19, 2011 | 02:02 PM
Bloomers's Avatar
Bloomers
Cornish Fasty
best are std bearings. but i put poly bushes in and its fine. although lots on here won't agree
Old Sep 19, 2011 | 05:36 PM
martysmartie
I have heard this, can't remember which ray round but I think Ford are bearings and GGR are bushes, and someone was saying the GGR ones spoiled the ride.
Martin
Old Sep 19, 2011 | 10:41 PM
dazzle740's Avatar
dazzle740
A lot of people recomend to put new ford bearings/bushes in the rear arms and either poly or solid mounts on the rear beam. But also highly recommended to change is the rear diff carrier to one of the uprated versions.
Old Sep 20, 2011 | 10:11 AM
STUCOS's Avatar
STUCOS
scs beam if your going 6deg,replacement standard bushes /ggr only once you see how the bush works you will understand,polly beam mounts and diff mount,and escos rear arb and 3dr front hubs and it will be spot on mate
cheeRS stu
Old Sep 20, 2011 | 03:28 PM
shortie's Avatar
shortie
We have a 6 degree rear beam on our 3dr & polybushed fitted by scs great mod to have in my opinion
Old Sep 21, 2011 | 02:06 PM
leo_cos's Avatar
leo_cos
Wat sort of cost is the scs 6degree beam?
Old Sep 22, 2011 | 12:53 PM
shortie's Avatar
shortie
£1350.00 fitted mate
Old Sep 22, 2011 | 08:10 PM
Turbosimpsons's Avatar
Turbosimpsons
Tony @ Turbosystems does them for £900 plus fitting
yatta
May 21, 2016 10:31 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
cossirob
Sep 3, 2015 09:17 PM
