Ford Focus ST225 (MK2) 2005-2010 Everything relating to the Mk2 ST225 preface & facelift versions from 2005 to 2010
st225 overboosting? help
Old Sep 16, 2011 | 12:00 PM
nobbycossie's Avatar
nobbycossie
Red face st225 overboosting? help
My 55 plate totally standard ST has started to overboost. For some reason when I squeeze the throttle gently the boost guage swings to about half then on full throttle goes off the guage!!!! It is not a guaging problem either because it feels like its overboosting! I loose power when it goes off the guage to (possibly spark blowing out)
Any ideas anyone?
Thanks in advance
Old Sep 16, 2011 | 12:11 PM
foci's Avatar
foci
It will be the boost control solenoid. common problem
Old Sep 16, 2011 | 12:12 PM
nobbycossie
Sweet, where is it located and is it easy to change as i don`t fancy taking it to a garage!!!!
Old Sep 16, 2011 | 12:14 PM
Carlos-Titx's Avatar
Carlos-Titx
Someone had a thread on here with the same problem with loads of info if you fancy a hunt around. Or google it and put in passionford first.
Old Sep 16, 2011 | 02:00 PM
nobbycossie
Well I took my drivers side wheel and arch liner out and I have found what appears to be a hose off but can`t find where it goes to??!!
See piccies below (taken from drivers side arch looking back), could this be my problem?
Old Sep 16, 2011 | 02:24 PM
martysmartie's Avatar
martysmartie
Won't be boost valve, they fail safe, i.e. no power would mean less boost, it's going to be a hose which goes from the valve to the actuator, or the one going from the compressor housing to the valve.
What you are experiencing is overboost protection!
Martin
Old Sep 26, 2011 | 01:15 PM
nobbycossie
Cheers for all the advice and steering me in the right direction. That hose I found off was in fact a drain hose from the scuttle panel and is supposed to be like that! I changed the boost control solenoid located behind the drivers side wheel arch liner on spec and car now runs like a dream so thanks everyone.
Old Sep 26, 2011 | 01:40 PM
foci's Avatar
foci
Glad to have helped
skypeller
Sep 19, 2015 09:58 PM
GTR_STU
Aug 28, 2015 01:02 PM
TIFF
Jan 1, 2006 10:15 AM
007
Nov 14, 2004 05:15 PM
