**REDUCED**v twin Go kart Highly modified engine 680cc 20hp briggs and stratton ?825
Non Ford parts & other stuff for saleIf its not for a Ford, or even not car part... this is the room to sell it!!
Starting a topic requires you to have purchased a gold membership.
**REDUCED**v twin Go kart Highly modified engine 680cc 20hp briggs and stratton £825
Formula 20hp V twin go kart for sale
The kart has a 20hp V twin briggs and stratton twin cylinder engine which has been highly tuned. It has a lightweight flywheel, lightened and balanced crank, titainium conrods, high compression pistons, reiforced valve springs, race carb, k&N air filter, full elecric start including a new drycell battery. The kart frame itself is in good condition and has a full disk brake setup on the rear axle along with it being chain driven. It comes with a full set of slick tyres, lightweight race wheels and a trolley to manuvre it around easily. This is a seriously quick bit of kit and will easily take a LARGER person within excess of 75 mph on a close circuit track.This is a 4 stroke kart which allows it to be used on most track as many dont allow 2 stroke due to the high noise level
£825 ono
***REDUCED PRICE***
Reason: reduced the price
