BD15 inlet Cam
Old Sep 15, 2011 | 01:40 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Default BD15 inlet Cam
Im thinking of changing my legendary AB07 inlet cam
Has anybody used a BD15 inlet ?
How did you find it ?
Steve
Old Sep 15, 2011 | 02:43 PM
R5FORD's Avatar
R5FORD
why dont you just buy a cossie doing all these mods to a cosworth rep tut tut
Old Sep 15, 2011 | 03:17 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
That would be boring lol
Might do a few other things over winter/new year as well
Steve
Old Sep 15, 2011 | 03:24 PM
BRAMMER's Avatar
BRAMMER
Will you be building the 200 block with the right pistons
Old Sep 15, 2011 | 03:26 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
That means spending even more money
Steve
Old Sep 16, 2011 | 03:54 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Up
Has nobody used this cam ?
Steve
Old Sep 16, 2011 | 04:23 AM
BRAMMER's Avatar
BRAMMER
Steve why don't you just ring Tony I'm sure he will tell you
Old Sep 16, 2011 | 05:55 AM
Moonstone Steve.'s Avatar
Moonstone Steve.
You will need valve cut outs in the pistons so its got to come apart surely???
Steve
Old Sep 16, 2011 | 06:12 AM
Turbosystems's Avatar
Turbosystems
Super Moderator
he's already rung me prior to this post
this is purely steve seeking some love and attention as he gets none from his wife
BD15 is one of my favourite cams we used it extensively in our 1980's touring car engines along with a bd14 exhaust cam with very specific secret squirrel cam timing figures
fast road engines we used different exhaust cams
The infamous dessert storm of that era ran the 15 14 combination
from the early 1990's we used modified bd15's as well as 16's
the most commonly used cams for fast road engines by us were those very trick expensive std ones that came free with the car
Old Sep 16, 2011 | 06:51 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
So is it worth me using one Tony ?
Steve
Old Sep 16, 2011 | 06:52 AM
Turbosystems
Super Moderator
not with those pistons
as I said to you on the phone we need to increase valve lift which isn't possible with your home spec engine
this is the reason we suggested the ab07 in the first place
Old Sep 16, 2011 | 06:54 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
LOL, i know i will need valve cutouts
What was the special BD15 you used then ?
Did it have more lift ?
As said on the phone i don't want to loose the bottom end.
Steve
Old Sep 16, 2011 | 06:58 AM
Turbosystems
Super Moderator
if you put a bd 15 in it as it is ,
it is the top end you'll loose as in bent valves roflol
and also pistons a rod or 2 and a bent crank
Old Sep 16, 2011 | 07:04 AM
Turbosystems
Super Moderator
Steve the best advice I can give you is to speak to your tuner
Old Sep 16, 2011 | 07:25 AM
BRAMMER's Avatar
BRAMMER
Best get sweetening her up as this next step could become expensive
Old Sep 16, 2011 | 07:30 AM
Turbosystems
Super Moderator
to be fair steve has no problem spending money on his car he just has a problem with his wife spending his money not on his car
Old Sep 16, 2011 | 07:31 AM
BRAMMER's Avatar
BRAMMER
Old Sep 16, 2011 | 07:32 AM
Turbosystems
Super Moderator
Are you referring to the cost of an engine build or the cost of his pending divorce
Old Sep 16, 2011 | 08:05 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Thats soooooooooooooo true lol
Steve
Old Sep 16, 2011 | 08:08 AM
Turbosystems
Super Moderator
look on the bright side steve when your kids get a bit older she will probably get herself a job and spend all her income on herself .Even more things from littlewoods but still none for your car
Don't worry steve she'll still be spending your money as well
Old Sep 16, 2011 | 08:37 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Do i get the 200 block built up with standard comp and valve cutouts then ?
Steve
Old Sep 16, 2011 | 08:39 AM
Turbosystems
Super Moderator
my advice is to ring your engine builder
or alternatively if he hasn't got a clue ring me
Old Sep 16, 2011 | 08:40 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
I ain't got 4hrs spare
Steve
Old Sep 16, 2011 | 08:42 AM
Turbosystems
Super Moderator
I haven't got 100 hours spare to spend building internet engines
Old Sep 16, 2011 | 08:47 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
I wouldn't mind if you had a land line as i can call that FREE for a hour
Steve
Old Sep 16, 2011 | 08:53 AM
Turbosystems
Super Moderator
I do have a land line you tight fooker lol
0898 .............. lol
01782511279
Old Sep 16, 2011 | 08:58 AM
Joshy's Avatar
Joshy
Dreamer
F**KING AFPML at this thread
Old Sep 16, 2011 | 09:03 AM
Turbosystems
Super Moderator
well I can't hear my phone ringing steve
fook me you must be tight you can't even ring when the calls are FREE
you must be busy ....... cooking cleaning washing and ironing then
Old Sep 16, 2011 | 09:32 AM
Weeksy's Avatar
Weeksy
Poor guy, he's getting a right shoeing here!
I am going to go for a bd16 inlet, 15 exhaust. Means I have a pair of 14's spare if anyone wants?
Thanks
Weeksy
Old Sep 16, 2011 | 09:38 AM
scoooby slayer's Avatar
scoooby slayer
just get tony to build you a touring car spec engine, job done never need touching again
Old Sep 16, 2011 | 02:52 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
I left work after my last post then had a load of chore's to do when i got home.
I have just called you on both your landline and mobile and got no answer
Steve
Old Sep 16, 2011 | 03:41 PM
Turbosimpsons's Avatar
Turbosimpsons
i'll buy your abo7 cam off you tony says it will suit my car spec
Old Sep 16, 2011 | 03:43 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Hows your back ?
Get well soon, Tony wants his teaboy back lol
Steve
Old Sep 16, 2011 | 04:04 PM
Turbosystems
Super Moderator
Steve
yep that's cos I was ignoring you
Old Sep 16, 2011 | 08:20 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Your not the only one
Nobody loves me
Steve
Old Sep 16, 2011 | 08:26 PM
Moonstone Steve.
Just get the money out and get it done.
Steve
Old Sep 16, 2011 | 08:32 PM
Turbosystems
Super Moderator
Steve
that applies to you as well moanstone
Old Sep 16, 2011 | 08:33 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Steve
I might do if it stays in front of yours
Steve
Old Sep 16, 2011 | 08:36 PM
Moonstone Steve.
In the new year Tone the moan
Steve
Old Sep 16, 2011 | 08:41 PM
Turbosystems
Super Moderator
we're doing a special christmas offer a free hub dyno run with every 15k you spend
