mk2 focus rs gearbox to cvh block?
Old Sep 14, 2011 | 05:30 PM
gus's Avatar
gus
Default mk2 focus rs gearbox to cvh block?
would the above box bolt upto a cvh block?
me and me mate was chatting and he has put the idea in me head now
no one has done it as far as i know (so that doesnt look good)
Old Sep 14, 2011 | 06:31 PM
crazycage's Avatar
crazycage
the bolt pattern is different mate so wont bolt up . the mk2 rs is a volvo lump.
Old Sep 14, 2011 | 06:45 PM
gus's Avatar
gus
yeah thats what i was thinking
how much is a custom belhousing?
is it any bigger then a mtx?
Old Sep 14, 2011 | 06:49 PM
Rick's Avatar
Rick
It isn't bigger no, but custom housing is a lot of cash. I don't see the point if I'm honest.
Rick
Old Sep 14, 2011 | 07:17 PM
crazycage's Avatar
crazycage
you can fit a mk1 focus rs box to a cvh if thats any good to you ?
Old Sep 14, 2011 | 07:28 PM
gus's Avatar
gus
what power these take?
Old Sep 14, 2011 | 07:32 PM
J1mbo's Avatar
J1mbo
B1mbo
How can a focus rs box go to cvh thought the starter would sit where the oil filter does?
Old Sep 14, 2011 | 07:34 PM
creator's Avatar
creator
They have seen over 400bhp gus.
Have you gone off the idea of using those gearboxes you had? After you broke one didnt you mate?
Old Sep 14, 2011 | 07:35 PM
creator's Avatar
creator
Could get a oil filter relocation kit jimbo? Would that not work?
Old Sep 14, 2011 | 07:38 PM
rsmark86's Avatar
rsmark86
Mk2 frs ratios would be totally wrong to a mate of mine had a 440bhp one and done stupid top end speeds, would go off the clock with ease
So unless your after top speed runs then it's not worth it
Old Sep 14, 2011 | 07:39 PM
J1mbo's Avatar
J1mbo
B1mbo
I thought the started would be too close to get a block in there, could be wrong but thats how I understood it!
Old Sep 14, 2011 | 07:41 PM
creator's Avatar
creator
Hhhmmm possibly pretty sure gary has tried it so sure he can tell us for sure
Old Sep 14, 2011 | 07:50 PM
gus's Avatar
gus
them hewland gearboxes i have will be going back in just thinking really
yeah did break one, god knows what went wrong with it as its just a pile of mush now
they should handle what im running easily enough
i dont really wanna put in what everyone else is using as i like the fact that mine is different from everyone elses
so as i say, just thinking out loud
Old Sep 14, 2011 | 07:56 PM
creator's Avatar
creator
Did you/are sending it back to hewland or just a gearbox specialist? Your car is ver my unique so defo understand about going for a different gearbox.doeant the jamsport 'q' plate escort run a hewland race box to?
rsmark86's Avatar
rsmark86
I heard you can change the bell housing on a mk1 frs box to make it front starter
Then you will have a quaife diff aswel as a bullet proof box and hydro clutch too
Old Sep 14, 2011 | 08:00 PM
gus's Avatar
gus
yeah jamsports escort runs a hewland box, its a tad expensive tho
mine will go back to the bloke that built it, to be honest im not expecting too much as its quite mullered
Old Sep 14, 2011 | 08:01 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
custom bell housing won't be cheap, that's for sure.
i'd just get a diesel mondeo mtx75 and whack an atb diff into it.
i run a frs box on my zetec turbo in my xr2, ratios will limit me to 164.5mph due to 15" rims on 195/45 tyres. bigger rims and better top end.
seem to be a very strong box though, shot peened gears as standard and atb already fitted.
Old Sep 14, 2011 | 08:34 PM
crazycage's Avatar
crazycage
swap the bell housing for a mondeo 1.8 or 2.0l front starter job done.
Old Oct 8, 2013 | 09:12 PM
studabear's Avatar
studabear
holy thread revival
So if bell housings are interchangeable, could I use a frs box with a 1.8 diesel mtx bell housing and retain cable clutch and mechanical speedo, but have a cable gear change and the fancy frs diff??
Old Oct 9, 2013 | 04:25 AM
crazycage's Avatar
crazycage
Yes,I have fitted two of these
Old Oct 9, 2013 | 05:18 AM
What about a ST170 gearbox.
Old Oct 9, 2013 | 06:06 AM
crazycage's Avatar
crazycage
Glenn to fit the st170 box to a cvh you need to cut the rear starter out of the bell and weld it into the front of the box
Old Oct 9, 2013 | 09:39 AM
XRT_si's Avatar
XRT_si
MTX will take over 500bhp. A few running more than that!
Old Oct 9, 2013 | 10:44 AM
QplateRST!'s Avatar
QplateRST!
1/4 mile beasty!!!!
I have broke 2 mtx's broke second gear twice
Old Oct 9, 2013 | 11:11 AM
XRT_si's Avatar
XRT_si
You must drive like a cunt Dean
Old Oct 9, 2013 | 11:28 AM
QplateRST!'s Avatar
QplateRST!
1/4 mile beasty!!!!
This would be true!!!
Old Oct 9, 2013 | 11:36 AM
R-A-J's Avatar
R-A-J
Beat me to it Si lol
Gus I have a mtx if you want it pal?? just sort the postage out if you do but I doubt you will as it has been done before lol
Old Oct 9, 2013 | 11:38 AM
R-A-J's Avatar
R-A-J
I would be up for a group buy in this if you or anyone else would be interested
http://quaife.co.uk/shop/products/qbe32g
but I think your problem is gus is the amount of torque mr field has extracted out of your cvh, it will love gearbox teeth
Rowe's Avatar
Rowe
Skint
^^^^ what he said!
Old Oct 9, 2013 | 11:39 AM
R-A-J's Avatar
R-A-J
you smell of poo x
Old Oct 9, 2013 | 11:40 AM
R-A-J's Avatar
R-A-J
st170 gearbox will be shite unless you get a custom gearkit which is circi Ł3800 odd. ratios are no good for boosted power
Old Oct 9, 2013 | 04:25 PM
gus's Avatar
gus
There is only a few if these left now mullet boy
I think quaife will be introducing a new gearbox to the mix next year as this is discontinued. They couldn't say how long they will be making serviceable parts for it
Kinda outs me off as that's where I am now
Will wait til probably the auto sport show ands see if they are making a new box
Old Oct 15, 2013 | 01:23 AM
stuart collins's Avatar
stuart collins
Originally Posted by studabear
holy thread revival
just buy the box and swap the diff like I said on the other thread and with the mondy box u don't need to cut the inner wing , gary makes u mounts and its in
Old Oct 15, 2013 | 12:58 PM
studabear's Avatar
studabear
Stu is that box a cable speedo with hydraulic clutch?
Old Oct 15, 2013 | 05:58 PM
stuart collins
cable linkage hydro clutch speedo drive front starter mk2 mondy td that's what is fitted to the orange 1 or I have just put the same box in the white 1 but its a rod shift from a mk 1 mondeo td , the petrol 1s are diferent again , have a look through his ebay shop
Old Nov 7, 2015 | 02:30 AM
Rsturbo519's Avatar
Rsturbo519
Can you use cable shift on focus rs clutch and flywheel?
Old Nov 8, 2015 | 11:53 PM
Rsturbo519's Avatar
Rsturbo519
Sorry that made no sense at all haha. I was meant to sat can you use cable clutch on focus rs clutch using a different thrust bearing, but going hydraulic now so all good.
I am going to put a mk2 mondeo diesel bell housing on frs box - can you run a mechanical speed that way? As from pics I have seen it looks like it's mechanical turned into electronical speedo
Old Nov 9, 2015 | 07:04 AM
Beach's Avatar
Beach
Well boys and girls it seems you're homework has been a little poor this week.
Give me roughly 3 months and I'll quite happily prove this is by far one of the best conversions for these cars. I've even posted a picture of the box mounted in my bay but won't be giving up too much until it's running. They fit better than any other gearbox made by ford. The ratios are great 185 mph at 8000 rpm, rated to 500 ft/lb amd I'm not going to even give away the best bit that makes this all so easy!!
Won't be long until mine is fitted now
Old Nov 9, 2015 | 07:07 AM
dodge8283's Avatar
dodge8283
Didnt NMS do this conversion over a year ago? i know when my car was there last it was certainly being done.
Old Nov 9, 2015 | 10:07 AM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
holy thread revival!!! 4 years ago this started.
