how long do i leave basecoat down before i lacquer?
put some layers of basecoat on my spoiler, how long do i leave it before i put the lacquer on?
I'd leave it overnight personally, let the base coat properly dry. I've done it too soon before and it always leaves a dull finish, presumably it's the lacquer re-activating the base coat, and the 2 coats almost mixing together. Never had a problem with letting the base coat harden off for a few hours and lacquering on top.
as soon as its dry enough to wipe over with a takrag really, so yeh touch dry. with waterbased, i usually apply, dry with a heatgun, n then once my gun is cleaned out and the lacquer mixed, its ready to go, which wud be 15 -20 mins tops really.
No longer than over night or you'll have to base coat it again.
Don't laquer it too early though as you'll get solvent pop in it (Air bubbles - feel like little specs of shite in the clear coat)
sridgett
Oct 1, 2015 07:30 PM
rsguy
44
Sep 29, 2015 03:29 PM
