Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
missing wiring plug please help!!!!!
Old Sep 14, 2011 | 01:34 PM
nahean's Avatar
nahean
Default missing wiring plug please help!!!!!
hello i am new to this form i have a 1.6 zetec ford focus on a 53 plate and i am missing a wiring plug which is causing the car idle rough if someone could tell me what that plug is and what i need to do thank you. i have also added some pictures the plug is behind the inlet manifold and on the right side of the alternator
[img=http://img851.imageshack.us/img851/2681/dsc00007c.th.jpg]
[img=http://img51.imageshack.us/img51/9462/dsc00006gwg.th.jpg]
Old Sep 16, 2011 | 06:52 PM
Bailes1992's Avatar
Bailes1992
That will be your MAP sensor. And yes it will cause rough idling and the engine to stall if you dip the clutch while moving.
Look along the injector loom and there should be a wire comming off it directly above the MAp sensor.
IainRS1700T
Sep 25, 2015 06:44 AM
wheelwizardrefurbs
Sep 24, 2015 08:35 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
jay030787
Sep 18, 2015 04:38 PM
Flatlinedan
Sep 18, 2015 12:41 PM
