Pug 306 problem/Think garage is wrong
Old Sep 13, 2011 | 04:48 PM
S2martin's Avatar
S2martin
Ex Full Price gold member
Default Pug 306 problem/Think garage is wrong
Hey guys,
I have a 2000 306 HDI as a work run about and it has a problem that i think the garage is wrong about, It drives fine then cuts out at total random moments.. When it cuts out is throws up the fault light on the dash and the car will not start.
The garage then read the code and reports a fueling problem and car will not start, But if you use the fob on the key to lock the car and unlock the car it starts and runs fine..
I am saying its an immobiliser fault the garage are saying its the fuel pump.. Anyone had any experiance with either?
Mart
Old Sep 13, 2011 | 04:54 PM
pee vee's Avatar
pee vee
dont the immobilizer cut power to the fuel pump when activated?
possible link there
Old Sep 13, 2011 | 05:14 PM
S2martin's Avatar
S2martin
Could possibly mate i dont actually know
Old Sep 13, 2011 | 05:22 PM
pee vee's Avatar
pee vee
I know a lot of aftermarket alarm/immobilizers are linked to the fuel pump.
Old Sep 13, 2011 | 05:29 PM
S2martin's Avatar
S2martin
Cheers, I might just get it out the garage and get an auto electrician to remove the alarm/immob first then see how it goes.. As if it does cut the fuel pump then that would explain it throwing the fault light up on the dash imo
Old Sep 14, 2011 | 07:23 AM
djmillsy's Avatar
djmillsy
Fife Radge
Iirc that seemed to be a common fault on some 306's the immobilizer coming on and doing what you said
Old Sep 14, 2011 | 07:43 AM
taz1787's Avatar
taz1787
Escort Cabriolet Owner
like said the immobiliser will be linked to fuel pump and ecu will sense no fuel when problem occurs
so will throw dash light on as it senses fuel problem
so when codes read will read fuel related problem
so as garage have just read the code there are half correct
and obviously when cleared the code ecu returns to normal so will start
so imho its the immobiliser cutting in and shutting off fuel pump if its aftermarket immobiliser then it could be removed easy enough
but if factory fit could be wired to ecu which makes it harder to remove
hope this helps
Old Sep 14, 2011 | 04:57 PM
S2martin's Avatar
S2martin
Cheers for the info guys, And yeah its a factory immobiliser ffs lol
Guess its a case of getting the ecu unlocked or something, Actually after visiting the garage today and talking to the main guy he agrees its probably the immob being a bitch and he has a auto electrician who can have a look at it for me..
Only other thing i can think of in the mean time is to wire the pump directly to a switch maybe to override the immob but im ringing the auto electrician tomorrow to see when he can have a look.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
A.t.p
Oct 23, 2015 07:54 PM
gcfcos
59
Oct 6, 2015 05:04 PM
rsguy
44
Sep 29, 2015 03:29 PM
DavidK
Sep 27, 2015 02:55 PM
