c20xe in a mk3 escort ?
how hard is it to mount...
can you use the custom bell housing the old skool lot use with the type9 with a bc box from a s1, and what clutch and flywheel would you use.
the engine ive seen is on carbs so easy to wire up ect.
thanks
thanks
The engine loom is totally separate from the car loom so easy to run the SFI if you wanted
Dr. Ickxs
Sep 15, 2015 10:15 PM
