Block n bits...
Old Sep 13, 2011 | 09:30 AM
Capri_Driver's Avatar
Capri_Driver
Default Block n bits...
First post, so hello to everyone on here, hope you are all well.
I hope I've got the right area for this, apologies if I havent mods!
I have afew cosworth parts I need to get rid of as I've desided to go V8 rather than Pinto turbo, and would like to know how much I should be asking for the parts, I have the following...
205 block - Apprently this is useable as is, and would do some years providing the HP's arent too imense, but it would benerfit from a rebore to be really scrupulous, witch when building an engine you want to be really dont you.
2 sets of YB standard pistons - one set in very good con, the others have smacked some valves but apprently are still very much useable.
1 set of standard YB rods - I think one of these Is no good, so it would be a set of 3 really.
1 cosworth 9 bolt flywheel crank - This needs a regrind apprently
1 set of Pinto injection rods - all good and stronger than standard pre injection type I'm told
1 Injection crank
There is also a cast alloy sump and pickup, an oil pump thats ment to be ok, and a dizzy. Asides from the sump, is the later worth bothering with?
Hoping the prices are enough to put some in the piggy bank for the 4.6 lump
Thanks for taking the time to read my post and a big thanks in advance!
gcfcos
59
Oct 6, 2015 05:04 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
AJC
Oct 1, 2015 06:47 PM
20/20 vision
Sep 29, 2015 11:27 AM
20/20 vision
Sep 28, 2015 03:03 PM
