Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
Cobra Bucket Seat Help
Old Sep 12, 2011 | 08:32 PM
Fum's Avatar
Fum
Default Cobra Bucket Seat Help
Hi peeps
Noobie to the forum here as i couldnt find a welcome section i thought id just go ahead and post.
I just brought a Cobra Monaco S seat and id like to stick it in my 2002 Reg Focus, im just havein issues finding a subframe for it.
Anybody know of anywhere thats sells them and sells them for a fairly good price as all the onces ive seen ahve been over £150.
Cheers peeps, look forward to gettin to knwo you all
Old Nov 25, 2011 | 03:39 PM
ajc.78's Avatar
ajc.78
st70 build underway
I bought the subframes for mine from larkspeed they are quick and reliable IIRC they cost about £100 each
the main advantage of buying the proper cobra subframes (as opposed to other brands) is they have mounting points on the subframes for seat belt pretensioners which means you can still use the seatbelts. Others such as sparco have no mounts and cannot be used with seatbelts
Although I don't use my focus on the road much driving on the road with harnesses is a pain so I have left the seatbelts in as well
the subframes bolt onto the seats and them bolt to the floor using the original mounting points the monaco s have holes in the bottom of the seats to base mount them to the frames the monaco pro can be side or base mounted with the proper subframes they bolt into the car in about 5 minutes
I have read a few posts complaining that the cobra mounts are too high and whilst they could be a bit lower I am fairly tall and havn't found them too bad
although a lot of people moan about the monaco being cheap and nasty I personally think they are good value for money and they are supportive enough on the track I have has a few incidents on track and they have been fine
al
stevecfrst1
Sep 30, 2015 05:18 AM
dirty-diesel
Sep 29, 2015 07:25 PM
SMILER258
Sep 28, 2015 09:04 AM
