need help pleas
hi to all
i have an escort 1.6 1991 (clx) carb
i am looking to drop something with injiction/turbo
any one got any iders??
and a moter witch i wont have to do too many moods
the loom i no i have to change
thanx jack
thanx jack
Probably the simplest one would be an RS turbo engine, although a zetec turbo won't be to hard either, depending on your experience. Have a look in the restorations thread for examples of both, I'm sure you'll find the info you need there somewhere. And welcome to the forum
I can't remember if the mk5's had the CVH or the Zetec.
If it's a CVH then
RST is probably the easiest if it's a CVH, particularly if you want to mess about with the tuning.
Anything else a, 2.0 Zetec would also be a good choice.
Zetec turbo, only if you have the cash I would say.
If it's a CVH then
All Zetecs are FI, so if yours is carb it will be CVH, you most likely can fettle with with carb tuning etc or do the said CVH turbo, i.e. RST engine for an easy hike in power.
Martin
Martin
