Non ford engines in fwd fords
Old Sep 9, 2011 | 08:04 PM
rsmark86's Avatar
rsmark86
Default Non ford engines in fwd fords
Like the ford mag this month doing the feature on non ford engines
Can anyone say how hard they are in say a mk3 escort
The c20xe has been done, but how hard is it to mount and could you use the rwd conversion bell housing to use say a rst box? But what clutch would be needed.
And the other interesting one is the civic type r vtec
I guess you would need a box from something like a eke
And also who would do a manifold to fit carbs to a st170 engine
Old Sep 9, 2011 | 08:07 PM
rsmark86's Avatar
rsmark86
The civic box I meant ek9
And the c20let would be a cool conversion
ontheway's Avatar
ontheway
i like the idea of a mazda 13b rotary with a fwd gearbox from a 323
Old Sep 9, 2011 | 08:10 PM
rsmark86's Avatar
rsmark86
That would be good or a pulsar lump fwd
Old Sep 9, 2011 | 08:24 PM
zippyobrien's Avatar
zippyobrien
Got a vtec lump goin in my escort mark. Just and I mean just goes in the bay with a custom pulley.
Had to move servo to drivers side.
Old Sep 9, 2011 | 09:02 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
i have an inlet to fit carbs to the ST170 lump mate
sold the rollers but still have the plenum bit also
Old Sep 9, 2011 | 09:07 PM
gjh's Avatar
gjh
I want to see a Rolls Royce merlin in a ka, would be a right laugh.
Old Sep 9, 2011 | 09:49 PM
rsmark86's Avatar
rsmark86
I should bring mine round yours then lol
Could just run a pedal box instead?
Old Sep 9, 2011 | 09:50 PM
rsmark86's Avatar
rsmark86
What sort of money would you want for that ? Just the manifold
Old Sep 9, 2011 | 09:54 PM
Dan j's Avatar
Dan j
Van modder
Pictures of the install mate sounds like a good idea
Old Sep 9, 2011 | 10:11 PM
Shonky's Avatar
Shonky
V6 Ka of Love
I have a Vauxhall V6 in my Ka, made mounts and hung them off the standard mounting points (+ a couple more), dropped the engine and vauxhall gearbox in (I had to buy a cable shift linkage box to make it easier to fit), took the vauxhall and ford shafts to a local prop/driveshaft company with the measurements and they made tubular shafts with vauxhall inners and ford outers, wiring was easy as the ecu loom is separate from the car loom
Old Sep 9, 2011 | 10:13 PM
Shonky's Avatar
Shonky
V6 Ka of Love
I've always fancied putting a vtec in a ka, it's not until you look closely at a vtec engine bay you realise the engine is on the wrong side which means a re-locate or replace with a pedal box into a small ford
Old Sep 9, 2011 | 10:16 PM
Shonky's Avatar
Shonky
V6 Ka of Love
Saab turbo engine would be another cracker!
Old Sep 10, 2011 | 08:43 AM
zippyobrien
Because I'm poor and peddle boxes cost money. So I've got a Mondeo servo and mc, removed the break bar and fitted the hydro clutch set up from the civic. Total cost, Ł10 for the Mondeo crap.
Also you can use the bottom half of the standard st170 manifold to fit carbs, done this to fit bike carbs to a mates Rs 1800
Old Sep 10, 2011 | 08:53 AM
zippyobrien
Ka would be an Easter installation ( as would mk zetec s, puma) due to have flat sections on inner wings to weld the civic mounts to.
Unlike my mk4 escort were I'm goin to have to box section them out. Tall engine aswell
Old Sep 10, 2011 | 08:55 AM
Tank Mike's Avatar
Tank Mike
Ford do it from the factory
Focus st and Rs mk2 have volvo engines
Fiestas 1.25, 1.4 and 1.6 have yamaha
Old Sep 10, 2011 | 09:10 AM
rsmark86's Avatar
rsmark86
Well I'm tempted to keep my escort and go st170 but what would you charge me to mount a c20xe or c20let
I think the vtec might be abit much for me
Old Sep 10, 2011 | 02:28 PM
xtatiana01x's Avatar
xtatiana01x
Mark just keep the escort and do the st170 on tb's like you wanted it's not the sort if car to turbo ect
Old Sep 10, 2011 | 02:40 PM
rsmark86's Avatar
rsmark86
Yeh but it's 1850 just for the trireme bodies, Ł500 for an engine, and then I need a injection fuel system
So carbs would be best
Old Sep 10, 2011 | 02:44 PM
I hate the thought or the sight of a non ford engine in a ford.
Old Sep 10, 2011 | 06:11 PM
James's Avatar
James
I love it, love how someone has taken something totally different and "made" it work, with some propper engineering & electrical skills.
Did anyone see the ka with audi S3 quattro engine and running gear at ford fair?
Old Sep 10, 2011 | 07:54 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
im after Ł125 for the manifold mate
personally i would go the audi 1.8 turbo route if i ever done a conversion again.
awesome engines
Old Sep 10, 2011 | 08:48 PM
rsmark86's Avatar
rsmark86
Ok mate will have a look about at bits to match
The ka at ford fair was cool
Aug 8, 2015 07:12 AM
Versus_Creations
24
Aug 5, 2015 09:32 PM
