rs turboengine missing
Old Sep 8, 2011 | 06:52 PM
mattyrs1's Avatar
mattyrs1
Default rs turboengine missing
can anyone help me, I have a problem with my rs engine- when im driving at low revs it is fine then soon as I get the turbo in it starts missing?? Its recently had new kent cam, fuel filter spark plugs dizzy cap and rotor arm plus k&n, any ideas guys?
Old Sep 8, 2011 | 07:38 PM
mattyrs1's Avatar
mattyrs1
can anyone help?
Old Sep 8, 2011 | 07:40 PM
grotty's Avatar
grotty
who did the timing
Old Sep 8, 2011 | 07:41 PM
stephenbatey's Avatar
stephenbatey
Boost cut? Is it chipped?
Old Sep 8, 2011 | 07:42 PM
mattyrs1's Avatar
mattyrs1
what you mean boost cut mate,
Old Sep 8, 2011 | 07:44 PM
mattyrs1's Avatar
mattyrs1
it is chipped, It used to do it with the old cam in- i hit the limiter one nite and it backfired and cleared , but since the new cam went in its come back,
Old Sep 8, 2011 | 07:45 PM
mattyrs1's Avatar
mattyrs1
my mate did the timing, he works for historic rally sports , so is trustworthy
Old Sep 8, 2011 | 07:51 PM
stephenbatey
Boost cut us when the boost is greater than the limit set by ecu.
Old Sep 8, 2011 | 07:54 PM
mattyrs1's Avatar
mattyrs1
so, does that mean its boosting too much? should i try turning the boost down a bit, not sure what its boosting at but dont think its high, just put the engine into a van
Old Sep 8, 2011 | 08:02 PM
stephenbatey
Get a tuner to set it up for you or it could end in tears.
Old Sep 8, 2011 | 08:04 PM
v man's Avatar
v man
Zee Germans are coming
did you gap the plugs
Old Sep 8, 2011 | 08:12 PM
mattyrs1's Avatar
mattyrs1
just spoke with my mate now he took the it to work today to have a good look at it and when he took spark plug 2 out it was coverd in oil, plus the engine is getting hot, ? would this explain the missing he reckons head gasket or the oil seal has gone
Old Sep 8, 2011 | 08:20 PM
mattyrs1's Avatar
mattyrs1
do any of you guys know what problem is when the plugs oil up
Old Sep 8, 2011 | 08:47 PM
v man's Avatar
v man
well oil is getting in the bore
does it smoke at all
can only be
stem seels
rings
head gasket
do a comp test and water pressure test they can tell you alsorts
Old Sep 8, 2011 | 08:50 PM
Steve E's Avatar
Steve E
Or running too rich ?
Old Sep 9, 2011 | 03:18 PM
mattyrs1's Avatar
mattyrs1
he did say it was smoking a bit, he took it into the garage at work noticed the temperature was getting high so he says he checked the plugs they were oily- tried starting it up then and it wouldn`t
gambo08
Feb 4, 2016 10:49 PM
mk1turboestate
Dec 2, 2015 08:31 PM
Fil
Sep 30, 2015 12:08 PM
Fiddy
21
Sep 29, 2015 06:10 PM
oldskooldanrst
Sep 27, 2015 04:02 PM
