what months and year does a car not need a CAT??
Old Sep 8, 2011 | 01:26 PM
paceo's Avatar
paceo
Default what months and year does a car not need a CAT??
is it pre august 1992??
ive got a golf vr6 april 1992 and the CAT is on its way out, thinking of going for a de-cat as there much cheaper!
Old Sep 8, 2011 | 01:47 PM
Danwood79's Avatar
Danwood79
I had a J reg escort and didn't need cat for mot, and my brother has a K reg escort and it needs a cat for mot.
Best asking at a mot station.
Old Sep 8, 2011 | 01:53 PM
RS 5tu's Avatar
RS 5tu
think its about 92 iirc, but it may not need a cat but its still got to pass emissions.
Old Sep 8, 2011 | 02:03 PM
Any car above 92/93 needs a cat.meeowwww.
Old Sep 8, 2011 | 02:12 PM
CosworthGuy's Avatar
CosworthGuy
3dr Cosworth owner
Im sure its any car registered after january 1993. so some k reg can and some cant
Old Sep 8, 2011 | 02:14 PM
cossiestu's Avatar
cossiestu
Mines April 92 build an has always passed a MOT without a cat if that helps?
Old Sep 8, 2011 | 02:16 PM
cozmeister's Avatar
cozmeister
More boost Igor!
The answer is here: http://forum.fordsierraclub.co.uk/vi...=MOT+catalytic
"For emission purposes vehicles are tested against details shown on the VIN and not the registration plate. Vehicles fitted with a different engine are tested according to which is older, engine or vehicle.
Catalytic convertors were introduced from 1st August 1992 and are compulsory after 1st August 1995. Vehicles first used between 01/08/92 and 31/07/95 are only cat tested if there is an exact match (re engine code) in the analyser database or in the Inservice Emissions book. Vehicles first used on or after 01/08/95 are cat tested using vehicle specific limits if there is an exact match. If there is no exact match it is cat tested using default limits, CO<=0.3%, HC<=200ppm"
Old Sep 9, 2011 | 05:28 PM
jed960's Avatar
jed960
At present no car requires a cat for the MOT as long as it meets the applicable emissions requirements, that will change from next year where a cat will be required for some cars.
To answer the original question, for a car first used between 01/08/86 and 31/07/92 the emissions limits are 3.5% CO and 1200 ppm HC, so no cat required.
Old Sep 9, 2011 | 05:30 PM
Carlos-Titx's Avatar
Carlos-Titx
Find a friendly MOT man
Old Sep 9, 2011 | 06:23 PM
tee-rex's Avatar
tee-rex
Jan 2012 any car which was fitted with a cat from new will need it to be fitted for an mot, vsi on the mot computer will tell the mot tester if the car in question had a cat from new.
There are loads of new things coming into the mot test next year and a lot of the old stuff dropped out,
Old Sep 9, 2011 | 07:26 PM
It's Czech Mate's Avatar
It's Czech Mate
At present no car needs a CAT to pass an MOT, just to pass the age related emmissions test
This is changing though I think but not yet
mk22door
49
Mar 26, 2022 07:15 AM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
track.focus'd
Aug 12, 2015 05:53 PM
marvin
Fiesta RS1800/RS Turbo
Aug 10, 2015 11:14 PM
gordyshreds
20
Aug 10, 2015 02:59 PM
