Compression for E85?
Old Sep 8, 2011 | 06:26 AM
ozmk1cos's Avatar
ozmk1cos
Default Compression for E85?
What compression would be nice for E85 I currently have 8:1 and its apart at the moment
Whats the thoughts on bumping it up a bit?
Its for a yb in a track car.
Old Sep 9, 2011 | 07:51 AM
ozmk1cos's Avatar
ozmk1cos
Has no one got thoughts on this?
I thought there would be a bit to gain even if it was just down to runnng less boost for the same power.
Old Sep 9, 2011 | 08:52 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
You wont get a straight answer that fits all applications for just on petrol as its not that simple let alone on E85.
If you beleive that 8:1 was optimum for your engine on petrol though, the same engine will probably work very well at 9:1 on E85
Or keep it at 8:1 and you can run some more timing.
Depends largely on how hard you are revving it, if its high rpm power you want, then higher compression is king.
Old Sep 10, 2011 | 09:35 AM
ozmk1cos's Avatar
ozmk1cos
Cheers Chip you made the decision easy for me. Im not chasing anymore revs so it will be staying as is.
Prickly_buzz
Dec 7, 2017 09:52 PM
Nov 1, 2015 06:53 PM
Fezman1
Oct 2, 2015 01:22 PM
IainRS1700T
Sep 25, 2015 06:44 AM
RS-Rikki
Sep 21, 2015 07:27 AM
