Ford Focus (All Models) This forum is for discussion of all things pertaining to the Ford Focus Range that doesnt belong in the seperate ST & RS sections..
Prob after lowering
Old Sep 7, 2011 | 01:56 AM
danme1987's Avatar
danme1987
Default Prob after lowering
I seem to suffer pretty bad from understeer after my lowering. Prob dropped it around 50-60mm and i just dont turn. Obviously this only happens when im giving it a bit but i can corner at 30 and its will be struggling for grip. any tips advice?
thanks
Old Sep 7, 2011 | 05:45 AM
smudger068's Avatar
smudger068
its probabley becuase were you have lowered it so much that the rear camber has increased majorly a person i know done this and had issues when only dropping it 25mm, becuase the garage put the camber back wrong!
Old Sep 7, 2011 | 12:37 PM
danme1987's Avatar
danme1987
would the rear camber make it understeer so bad? Ive had a geo done afterwards and all corners are within spec?
Old Sep 7, 2011 | 12:44 PM
dojj's Avatar
dojj
Resident Wrestling Legend
you need to get the geometry reset, a 60mm drop will move everything out by miles
if in doubt, ask another garage or post up some pics of the front and rear looking at the front or back to show the camber
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Fudgey
21
Sep 30, 2015 06:19 PM
SMILER258
Sep 28, 2015 09:04 AM
gcfcos
88
Sep 15, 2015 03:48 PM
