whats needed for my next power increase?
Old Sep 6, 2011 | 08:59 PM
Bloomers's Avatar
Bloomers
Cornish Fasty
Default whats needed for my next power increase?
I'm toying with the idea of upping the power on my cos a bit more. its currently making 365 and 390lbft at 1.8bar.
Spec is...
msd chip
stg 3 t3 (34 comp wheel) .48 ex housing
803's
light head work
rebuilt 20k ago at std comp
got the usual supporting mods aswell.
whats the next bits that would be required? still on std cams, so i guess they should go. which turbo and injectors would suit best?
ta
Old Sep 6, 2011 | 09:07 PM
Derby_Gav's Avatar
Derby_Gav
Why do I feel that someone will mention t38 and ab07?!
Old Sep 6, 2011 | 09:25 PM
KSA-Cossie's Avatar
KSA-Cossie
T38 and AB07 cam lol,or go the MSD 380 hp conversion mate.
Old Sep 6, 2011 | 09:27 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
You already have a lot of power and torque for 1.8bar boost on greens
Steve
Old Sep 6, 2011 | 09:33 PM
Bloomers's Avatar
Bloomers
Cornish Fasty
lol, i was wondering if the ab07 would be mentioned... piston machining needed?
Old Sep 6, 2011 | 09:36 PM
Bloomers's Avatar
Bloomers
Cornish Fasty
would i noticed the increase? or would the power be a bit more progressive and usable
Steve
it made very good figures, but Martin said its on the limit of whats the greens will do and was starting a lean off a bit at the top
Old Sep 6, 2011 | 09:38 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
AB07 fits straight in with no piston mods
No chance of feeling any difference with MSDs 380 conversion with what you already have.
If it was me i would just change the exhaust housing to a .55, AB07 inlet cam and 55lb injectors.
Steve
Old Sep 6, 2011 | 09:40 PM
Bloomers's Avatar
Bloomers
Cornish Fasty
that as a pair of an inlet cam?
Old Sep 6, 2011 | 09:41 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Just inlet
Steve
Old Sep 6, 2011 | 09:50 PM
Bloomers's Avatar
Bloomers
Cornish Fasty
cool. any idea on power after that?
Old Sep 6, 2011 | 09:53 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
No idea, every set of rollers read different.
Just use the same one before and after changing.
Steve
Old Sep 6, 2011 | 09:59 PM
Cilly-jey's Avatar
Cilly-jey
iv gone t34.63 on grays with standard comp, feels as responsive as it did on t3 and greens but the power dont fall off at all. msd chip in mine
Old Sep 6, 2011 | 10:01 PM
xr_craig's Avatar
xr_craig
Fuck that, if your changing then why piss about putting a .55 on? If you want more power surely a T38 or whatever you fancy would be better? To me it just seems like a fair bit of expense for not that much gain.
Old Sep 6, 2011 | 10:21 PM
JamesH's Avatar
JamesH
What power and torque would you like?
Old Sep 6, 2011 | 10:28 PM
Bloomers's Avatar
Bloomers
Cornish Fasty
would like to poke above 400 really. problem is, i've been doing the odd track day and 'ring trip with a 911 gt3, e92 m3 and r35 gtr. So my poor old cos has been seeming lacking.
i know its silly mixing with the bigger boys, but if it can be done why not?
'spose i ought to dump the tractor transmission, though.
Old Sep 7, 2011 | 06:16 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
To be honest the power i have now is not as usable all the time like it was with my T34.55.
The power held on better when i changed from a .48 upto the .55 i just didn't have the AB07 inlet cam which made a big change in the way the power holds on after peak power with my current set up over a standard inlet cam.
Yes my T38 is fast but for a all round driveable set up i would go back to the T34.55, AB07 inlet cam, ported head and 55lb injectors.
Steve
Old Sep 7, 2011 | 06:19 AM
R5FORD's Avatar
R5FORD
Buy my roller bearing t38 will get you 450+
Old Sep 7, 2011 | 09:19 AM
Bloomers's Avatar
Bloomers
Cornish Fasty
so, in summary... Cam, diff ex housing or t38 and 55lbs?
Old Sep 7, 2011 | 09:28 AM
Turbosystems's Avatar
Turbosystems
Super Moderator
Steve
I can assure you steve that if you did you would soon be swapping back to a bigger turbo
t34/t35 can make reasonable power but they are being worked far to hard to achieve this and have a very short short life expectancy at this level
Old Sep 7, 2011 | 11:07 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
I wont win any RR Days with a T34.55
All round i think it was a more usable car with the T34.55 but you can't beat the grunt it has now lol (well only more )
Steve
Old Sep 7, 2011 | 11:34 AM
R5FORD's Avatar
R5FORD
T38
Cam
Injectors
Remap
Old Sep 7, 2011 | 12:47 PM
KSA-Cossie's Avatar
KSA-Cossie
Originally Posted by R5FORD
T38
Cam
Injectors
Remap
Bang on Aaron mate,that's where my money would go
Old Sep 7, 2011 | 12:58 PM
R5FORD's Avatar
R5FORD
ps Go for a RB T38 to spool quicker
Old Sep 7, 2011 | 03:08 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Nothing wrong with a TT T38 journel bearing one
Steve
Old Sep 7, 2011 | 03:32 PM
scoooby slayer's Avatar
scoooby slayer
honestly just fit a gt30 and injectors job done, forget the t38 there old now had there day
if it was my money it would be modern bb turbo without question. the turbo will yield your biggest gains for the least ŁŁŁ
Old Sep 7, 2011 | 03:34 PM
R5FORD's Avatar
R5FORD
The GT's old aswel
Old Sep 7, 2011 | 03:39 PM
R4N SS's Avatar
R4N SS
Sack the t38 off and get a gt30
Old Sep 7, 2011 | 03:44 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Its still better than some peoples T4s lol
Steve
Old Sep 7, 2011 | 05:02 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
i have a gt30 on mine with 500 bhp and a mate of mine had a 440ish mad set up on vipec with a t38 hes just fitted a hart inlet and a rb t38 ( he says the spool up is much better now ) and mark told him hes getting close to 500 now but i guess the turbo is right on its limit and he only runs 2 bar of boost i think wear mine runs 2.6 and i dont know what sort of torque he has havent put the too against each other yet but dans is a very fast car!
ginner
13
Aug 30, 2015 08:40 AM
Bailes1992
Aug 16, 2015 07:14 PM
col93saphcos
Aug 7, 2015 03:21 PM
blakey100
Aug 4, 2015 08:17 PM
