center box on 3dr cossie
i when i bought my 3 dr someone had put a shite exhaust system on it. so nows the time to get rid it has a center box and obviously a backbox. was just wondering wot difference would it make if i just went straight through and just have the back box ???????
wud i need to get the map looked at or can i just go ahead and do it ???
jas
[QUOTE=R5FORD;5615917]Extremly loud and droney.. Mine was louder than the legal limit at 4000rpm on idle
[/QUOTE
really wow that is loud ah well louder the better ithink
but will i need map adjusting ?
[/QUOTEreally wow that is loud ah well louder the better ithink
atabout 40-50mph it will do your head in.
I replaced the box in mine as didnt like it at all. On boost tho it sounded ace but you cant drive around everywhere on full boost so it had to go
bet it sounded ace ! am gonna try it with and without.. does anyone know if it will need the map adjusting ??
I removed the centre box from my 2wd saff and it sounded awesome, with no noticable drone difference inside the car, but when i did the same on my 4x4 ( different manifold ) it was terrible and the drone was unbearable so it got put back in.
I removed the rear box on my Esc cos as they cant be seen like the saffs can, the noise was lovely and no extra drone!!
Hope that helps.
Hope that helps.
Hope that helps.
Hope that helps.
ohhhhh yes that helps.
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 3, 2015 04:08 PM
