HP Laptop cheap as chips.
Purchased a desktop a few months ago now and the laptops just collecting dust.
About a year old now. few war wounds of going offshore with it.
Bad bits first
The corner has started to peel off, i have a pic, its only a small bit of the corner thats just popped off but i guess a bit of glue will sort it out.
The left click button on the mouse pad is a bit wonky, it slides to the left but still works perfectly.
On start up a battery warning comes up, its an internal battery i think that needs replaced, saying that the main battery doesnt last if not plugged in.
The ESC key has escaped.
Small bits of paint chipped off the speaker grill bit .
Apart from all that it runs flawlessly, never had an issue with it.
The screen is immaculate and the display is perfect.
4usb ports HDMI port loads of other ports. Webcam
Running windows vista, ill do a clean install when it sells, ill also throw in the recovery cds although you wont need them to recover the laptop.
Ill psot the specs now.
HP Pavilion dv6 notebook pc
Rating 4.6 WEI
Amd athlon x2 dual core ql 65 2.10ghz
Memory (ram) 3gb
32bit os
250Gb
Looking for £200
This is a perfectly working laptop, just a bit tatty and marked up.
Just to add, there is a remote with it too that slides into the side of the laptop. its 15.6" widescreen and its fooking cheap.
£200
Bad bits first
The corner has started to peel off, i have a pic, its only a small bit of the corner thats just popped off but i guess a bit of glue will sort it out. The left click button on the mouse pad is a bit wonky, it slides to the left but still works perfectly.
Rating 4.6 WEI
Memory (ram) 3gb
32bit os
250Gb
Looking for £200
£200
i have this exact laptop but the 4gb ram and 500gig hdd. defo a solid laptop! the battery error at the screen means you just need to get a new battery, i have the same error but it runs fine and i cba to buy a new batt bcz i usually use it at my desk!
£200 is very cheap in my opinion.
a bargain for anyone looking for a decent laptop at a cheap price.
Cheers mate, it really is a great laptop. The battery has never bothered me either.
Really cheap and will make someone a great laptop.
Its blown my 2 previous sony vaio's out of the water, they were just shite
And for the fooking cameras i have i really should get better pics up tomorrow
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
SMILER258
Sep 28, 2015 09:04 AM
