Focus ST170 Cam Timing
Old Aug 24, 2011 | 08:17 PM
blk-Mk5-zs's Avatar
blk-Mk5-zs
Default Focus ST170 Cam Timing
can i replace the inlet pulley with a standard zetec pulley and time i up properly and not lose much power?
cheers
Old Aug 27, 2011 | 07:58 PM
Sp3no's Avatar
Sp3no
You will have to delete the VVT first and then run aftermarket managment, you would lose drivability on standard cam but it would allow for a better choice of aftermarket inlet cams in the future as timing up aftermarket cams with the VVT fitted is tricky to say the least.
salsheikh
Ford Focus ST Parts for Sale
Oct 6, 2019 07:56 PM
salsheikh
Ford Focus RS Parts for Sale.
Aug 20, 2015 12:22 PM
Palethorpe01
15
Aug 18, 2015 06:09 AM
gordyshreds
20
Aug 10, 2015 02:59 PM
