Compbrake top mounts, spec-R breather 17" wolfrace alloys long wheel bolts and more!!
Found more bits to clear out! the garage is nearly empty enough to put the car in!
Compbrake top mounts, brand new. You will need the sleeve nuts and washers from compbrake (these cost £12 total) Im after £70, they are £100 from compbrake with a silly delivery time (mine took 4 weeks to come!) (PROV SOLD)
A freshly powder coated brake bias valve plate, goes between the rear chassis legs and mounts the valves. £10
Spec-r breather set up, good condition, few marks £50 was £90 new
K&N, looks okay, could do with a good clean! £10 (SOLD)
12 Long wheel nuts, used for fitting cossy wheels and spacers. I used 12 and 4 locking bolts £20 (think these are over £40 from speedshack)
17" Wolfrace Alloys, all in great condition (literally nearly new!) they came with my car but aren't really my thing. The tyres are in great shape (goodyear eagle's) with loads of tread left (over 5mm id say). One alloy has a slight kerb bruise, and two others have VERY light kerb marks (hardly worth mentioning). Even have the original primer on the insides. Pics are with out a good clean!
They are ET38 and 7J wide, multi filament PCD 100 and 108 so fit everything from new minis, vauxhalls ford etcetc.
£200
Rob,
£200
Rob,
Hi guys, luke you have PM, Craig cheers for the offer mate i'll get back to you if i need them,
Mark, yea although im personally not a big fan of the wheels some one out there must like them, plus they are a set of decent tyres for the price.
Rob,
Rob,
jessie_rs
11
Jun 3, 2019 04:57 PM
matman
Sep 9, 2015 05:45 PM
