Mk6 escort/gti heated front screen plug and play set up £25 delivered
This has only been removed from the car as it's being scrapped due to engine failure, i retro fitted this myself as heated front screen for me is a must and mine did not come with it, soon as winter comes and others are scrapping the ice off the windscreen you will be glad you did too lol
Included is the split heated front and rear screen switch to replace the rear only switch you currently have in the dash, the wiring for the front screen button is already there just tucked away ( but check before buying this please as that is down to you, will only take minutes to pop the switch out and see the other plug behind taped up ready)
On mine the plug for heated front screen was already there with wiring just taped up from factory so a 2 second job to plug it in,
The under bonnet wiring consist of heated screen loom, relay and fuse, along with heated washer jet loom as it comes all as 1,
There is no cutting of wires/soldering/bodging needed with this, just plug it in and connect to battery and earth and job done, then phone your insurance company and tell them your old screen is cracked and get them to replace with a nice new heated screen for the cost of your excess
Best mod i did on my escort gti by far,
Pic of loom and switch etc
£25 delivered to your door
Thanks
Marc
Thanks
Marc
track.focus'd
Aug 12, 2015 05:53 PM
Graceland
Jul 31, 2015 10:34 AM
salsheikh
Alloy wheels and ICE for sale
Jul 30, 2015 08:45 PM
