Escort rs2k tarmac rally car
Old Aug 14, 2011 | 11:53 AM
ryan81's Avatar
ryan81
Default Escort rs2k tarmac rally car
1993 ESCORT RS 2000 MK5 RALLY CAR (with mk6 front)
2012 MSA LOG BOOKED
2.0 16v Engine 150bhp
new timing chain , pulley ,guides , tensioner
new cylinder head
new starter motor
major service
k&n induction kit
tublar manifold
de cat
stainles steel exhaust (96db @4500 rpm)
oil catch tank
motor sport driveshafts very strong
quaife lsd
quaife straight cut gearbox
short shift
ib5 box
paddle clutch
l&b flywheel
gaz gold coil overs
rose jointed bottom arms (seem welded)
ap 4 pots
new rotors
ds2500 pads
new brake fluid
cosworth rear calipers with cable back up
ds2500 pads
new discs
all braided brake lines (run inside of car)
brake bias valve
vertical hydraulic hand brake
mechanical back up hand brake
et 13 alloys 15
200/585/R15 CR311 x12
wet set also
5th spare
alloy fuel tank
swirl pot
motorsport pump
all in a fireproof box
EARLS braided fuel line all through
EARLS fittings
Proper bulkhead fittings
red top battery
mba managment
oil / fuel pressure gauges
switches / relays / wiring for external bonnet pod
switch for fuel pump
push button start
engine kill switch internal / external
map reading light
potti socket
large rev counter in original posistion
new steering column fitted
full safety devices roll cage with additional rear bracing also triangulated to fron struts, harness rear bar
fully seam welded chasis
box section seat bars
navigators foot rest , horn
plumbed in fire ext engine and fuel cell
hand held fire ext
omp seats expiry 2016
6 point harnasses expiry 2012
intercom system
painted white inside
ext floor painted white
lexan windows with sliders
removable bonnet as second one has escort cosworth bonnet pod bonded on , with 2x 9" fogs , 2x 9" driving lights for nigh stages
exterior arch extensions , cossie rear spoiler , maxi roof intake / vent, mud flaps , alloy brackets
i have alot of spares , gearbox , sub frame , lights , rads ,alloy wheels, and a mk6 rs 2000 3 door car
when you rev these cars , they take off very well , great club car (eats 205 all day)
its great on the handbrake
got two option i sell this and go for a grp4 mk2 (with a ford lump not vauxhall)
or
sart going for maxi spec over the winter with it
£7000
its now colour coded , and has dtm cup wing mirrors, escos lower spoiler
matman
Sep 9, 2015 05:45 PM
allye
Alloy wheels and ICE for sale
Aug 11, 2015 09:49 PM
Old ford
Jul 31, 2015 06:50 AM
