conking out rs2000
ive a rs2000 4x4 with a 2.3 conversion on it but recently its been conking at junctions turn key starts up,had alternater checked out thoroughly and replaced alternater to start cable,just put a more powerfull battery in it now,but still running down ??????????????? help some one said earthin on the engine maybe cause !!!!!!!!!! how do i and where do i conect that ive spent a good load a money keeping this car alive but im at my witts any one help my e-mail is ishy_46@msn
next time it does it try running a cable from the battery to the starter. if it stats you got a fucked ignition wire. i had this problem and have fitted a starter button. if its earths you need to go around looking at them and check for corrosion. theres one under the air box and on the drivers side and on the bat
Pwrs2k
120
Oct 16, 2015 03:16 PM
Fordmad!
15
Sep 27, 2015 06:24 PM
