RB T38 SCS Spec
As above got my Roller bearing T38 its one of harvey spec turbos, It produced 460hp and 380ish lbs/ft, That was at 30psi only.
The turbo has done 10miles.
The inlet housing has been polished and painted red. Does have a slight chip in the paint. ( check photo below). If you want to change the colour all you have to do is get it re-polished (£15) and then painted (not sure how much this would cost)
The turbo is virtually brand new, no play etc if you need you can ask Harvey or Jim to vouch for the turbo
Im looking for £900.
There you go better to get it from the man himself mr gibbs.
Jim my engine was speced higher for potentiol power increase iirc. All i had to donwas change the injectors and turbo.
