Efi cosworth management for escort rs turbo
Selling my cossie management parts suitable for use on escort rs turbo.
Quick rundown:-
-level 6 ecu with wasted spark board and pectel board, plus chip although this will be re-written when you have it set up.
-Green injectors
-Coil pack, twin ignition amps
-Efi inlet manifold, been welded up and smoothed oddkidd creations style, then powdercoated gloss black. Other parts powdercoated gloss black to like fuel rail, coil pack bracket, alternator bracket.
-Vernier pulley, cam trigger set up.
-Cossie 2wd throttle body with accelerator bracket from Jano, short accelerator cable.
-Sierra 1.8 alternator and bottom crank trigger set up.
-All new gaskets, new air and water sensors
Needed to complete is a engine bay loom, a coil pack loom (about £60), a 3 bar map sensor, and a throttle position sensor, then someone who knows what they're doing (i only recommend Jano) to fit it all and get it set up.
£600
07970 509204 if u want to get hold of me instantly, wont be online that much this weekend
Couple of pics of some of the parts
Quick rundown:-
-Green injectors
£600
muz
Aug 16, 2015 12:57 PM
Aug 14, 2015 07:29 AM
