4x4 sapphire cosworth forsale (now sold)
Old Jul 29, 2011 | 03:12 PM
3dr cossie's Avatar
3dr cossie
Default 4x4 sapphire cosworth forsale (now sold)
have decided i want to build a 3dr track car and have found a shell, so decided to sell my sapphire cosworth.
i bought it just after christmas from a guy in Blackpool
its just about to turn 90k and has MOT till march next year and taxed till end of september
The shell has never been welded, the rear arches are completely rust free, the only bit of rust is a very small scab on the front drivers side lip.
The engine is very good, its running MSD wasted spark, has uprated fan loom. I've just fitted a brand new radtec alloy radiator. it has a pro alloy 500 intercooler.
Its running a T34.63, not very old and the engine does not smoke. When i bought it i was told it was running aprox 380 BHP and 400 lbft of torque. it goes very well.
It has the cloth interior which is in very good condition, but the door cards do have some shrinkage.
its lowered on Koni shocks and springs
Heres some pics
will put some better pics up later
looing for £7250 ono with comps or £6750 with standard sharktooth alloys running R888's on them
cheers, all comments welcome good or bad
If it doen't sell, i will break it as i should be able to get roughly the same money back for it in bits
i've decided its too good to break but would be open to px's on anything ford so WHY?
cheers Matthew
Old Jul 29, 2011 | 03:14 PM
3dr cossie's Avatar
3dr cossie
forgot to add its running siemenns 55lb injectors aswell, has uprated fuel pump, full mongoose exhaust system, uprated breather system.
i've recently fitted a new alternator, gear knob and gear gaitor. It has an RS centre on the steering wheel.
It has a paddle clutch fitted
cheers Matthew
Old Jul 29, 2011 | 09:15 PM
scottyrs's Avatar
scottyrs
DURHAM RSOC
lovely saff mate good luck with the sale
Old Jul 29, 2011 | 09:41 PM
AJC's Avatar
AJC
It might be worth adding that this belonged to Nick who used to work at MSD. I know the previous 3 owners and can vouch for this car. Certainly far too good to break. And looks great on those wheels.
Old Jul 30, 2011 | 02:23 AM
rsmark86's Avatar
rsmark86
thats real nice..... but i cant have another cossie
Old Jul 30, 2011 | 08:32 AM
Eigdoog's Avatar
Eigdoog
±§~Quadzackular~§±
Good luck with the sale! Looks the sex from the side!
Old Jul 30, 2011 | 09:13 AM
3dr cossie's Avatar
3dr cossie
cheers for the comments, it just seems like sapps aren't selling and more and more people are breaking them
cheers Matthew
Old Jul 30, 2011 | 09:25 AM
kosienutter's Avatar
kosienutter
Last Time, Get Off PF FFS
Dont break that, that look like a very nice example there, good luck with the sale.
Old Jul 30, 2011 | 02:02 PM
Smit's Avatar
Smit
The 60ft Launch King
Lovely car there Matt, looks ace on them wheels
Old Jul 30, 2011 | 08:35 PM
3dr cossie's Avatar
3dr cossie
more pics from today
also it has anti lag and launch control fitted
cheers Matthew
Old Jul 31, 2011 | 08:38 AM
rs_traynor's Avatar
rs_traynor
stage4 2wd cosworth
cracker
Old Aug 9, 2011 | 04:28 PM
3dr cossie's Avatar
3dr cossie
price dropped to £6750 or £6250 on standard wheels
cheers Matthew
Old Aug 9, 2011 | 08:41 PM
Danielbetty's Avatar
Danielbetty
You got anymore info on engine??
Old Aug 9, 2011 | 08:57 PM
TrevCos's Avatar
TrevCos
Lovely looking motor. Wheels not really to my taste, I'd prefer the sharktooths myself, but really nice car anyway and I know a lot of people do like those wheels. Cracking car.
Old Aug 10, 2011 | 06:39 AM
3dr cossie's Avatar
3dr cossie
i didn't do any of the work, but will look through the history and post later
cheers Matthew
Old Aug 10, 2011 | 12:29 PM
3dr cossie's Avatar
3dr cossie
i've decided its too good to break but would be open to px's on anything ford as i need the money for my latest project, so WHY?
cheers Matthew
Old Aug 10, 2011 | 01:09 PM
bigryrs's Avatar
bigryrs
RSHoleinator
Thats a cracking looking car mate and a steal at that price!
Old Aug 10, 2011 | 07:34 PM
3dr cossie's Avatar
3dr cossie
just been looking through all the receipts.
A lad called Nick who used to own this car worked ar motorsport developments at the time and there are several job sheets from them.
the first sheet has listed
polish YB crankshaft bearing surfaces,
supply and fit the following:-
crankshaft main & big end bearings
crankshaft thrust washers
front and rear cranshaft oil seals
front timing cover gasket
aux shaft thrust plate
oil pump and drive
con rod bolts (std)
sump seals
timing belt & tensioner
3 bar map sensor
power steering rack (new)
cam cover half moon seals
turbocharger oil return gasket.
the second job sheet reads as follows:-
remove, overhaul & refit cylinder head with new guides, cam bearings, stem seals and recut seats.
supply and fit cometic multilayer steel gasket
supply and fit new head bolts
supply and fit new exhaust manifold gaskets
supply and fit new cometic inlet & plenum gaskets
supply and fit new coolant sensors for ecu and dash
supply and fit new cam cover gasket
supply and fit new alternator belts and powersteering belts
supply and fit 2 new heater matrix hoses, renew both matrix seals and new header tank
supply and fit new 82 degree stat
supply and fit new steering column bush
supply and fit adjustable front tca's
supply and fit new alcon paddle clutch
replace all crankcase breather hoses
live map engine with siemens 55lb injectors and closed loop lambda control.
other receipts from MSD include a new T34 turbo,
new bosch 044 fuel pump
supply and fit wasted spark conversion
theres over 25 reciepts from ford for parts
there is also thousands of pounds worth of reciepts in the history file for this car
cheers Matthew
Old Aug 11, 2011 | 03:28 PM
R4N SS's Avatar
R4N SS
bargain and a lovely example
Old Aug 15, 2011 | 12:09 PM
3dr cossie's Avatar
3dr cossie
right, have picked up my new shell so need rid,
cheers Matthew
Old Aug 28, 2011 | 10:04 PM
3dr cossie's Avatar
3dr cossie
Bttt
no one intersted?
Old Aug 28, 2011 | 10:14 PM
Cossy Chris's Avatar
Cossy Chris
I could be mate just trying to sell my evo.
Old Aug 28, 2011 | 10:23 PM
3dr cossie's Avatar
3dr cossie
no worries, just let me know
cheers Matthew
Old Aug 31, 2011 | 12:31 PM
3dr cossie's Avatar
3dr cossie
have a priced it too high as not had any interest so far?
cheers Matthew
Old Aug 31, 2011 | 01:27 PM
mk2 escort boy's Avatar
mk2 escort boy
ill swap it for my bmw
Old Aug 31, 2011 | 02:49 PM
3dr cossie's Avatar
3dr cossie
i need the money for a new project so would only be after a swap for something ford and cheaper
cheers Matthew
Old Sep 4, 2011 | 07:12 AM
rsmark86's Avatar
rsmark86
My escort plus abit of cash
Old Sep 4, 2011 | 08:31 AM
AJC's Avatar
AJC
Really don't want to see this car get broke
Have you got it advertised anywhere else?
Old Sep 4, 2011 | 09:29 AM
JRG1's Avatar
JRG1
thats stunning! if i sell my ST id be interested,i'll keep an eye on this
Old Sep 12, 2011 | 08:56 AM
3dr cossie's Avatar
3dr cossie
bttt for today,
£6500 with wheels £6000 on standard wheels
cheers Matthew
Old Sep 12, 2011 | 07:22 PM
rsmark86's Avatar
rsmark86
You just looking for a cash sale mate,
Glws mate
Old Sep 12, 2011 | 08:11 PM
3dr cossie's Avatar
3dr cossie
Glws mate
hi mark, i really could do with the cash, as i've just bought a 3dr sierra shell with full multipoint cage, but it reall yis a bare shell, and i need the cash to build it up into a road rally car.
cheers Matthew
Old Sep 13, 2011 | 10:06 AM
rsmark86's Avatar
rsmark86
cheers Matthew
That's cool mate no problems good luck with it
Old Sep 20, 2011 | 12:31 PM
3dr cossie's Avatar
3dr cossie
BTTT, for today
Old Sep 20, 2011 | 01:26 PM
rs53ash's Avatar
rs53ash
Would you take a mk1 focus rs in px ?
Old Sep 20, 2011 | 06:41 PM
3dr cossie's Avatar
3dr cossie
do you have any pics and what sort of price are you after for it?
cheers Matthew
Old Sep 22, 2011 | 11:41 AM
rs53ash's Avatar
rs53ash
Pm'd mate
Old Oct 23, 2011 | 09:35 AM
3dr cossie's Avatar
3dr cossie
BTTT, car is currently sorned till the better weather, open to offers but not of £5000 as thats all i seem to get offered and the car is worth alot more
cheers Matthew
Old Nov 15, 2011 | 02:00 PM
3dr cossie's Avatar
3dr cossie
will swap for a ST220 estate petrol version or cheaper sporty ford plus cash my way WHY?
cheers Matthew
Old Nov 15, 2011 | 04:32 PM
booner999's Avatar
booner999
M3 EVO Cab plus some cash? £1500?
