A few parts
Old Jul 25, 2011 | 08:45 PM
studabear's Avatar
studabear
Default A few parts
I'm changing management system on my turbo cab, so these bits are no longer required.
Map sensor bracket £10, modded so only has 1 attachment for fixing to heater box on rs turbo
Ignition amp and heatsoak (amp is genuine part, not done 150miles from matt lewis) £35
3 bar map sensor, again genunine weber from msd £40
blue injectors £30
All prices plus postage or you can collect from me at ford fair
I have 2 L6 ecu's, both have had wasted spark fitted and then removed, they work but I have to keep them indoors in the winter, as when very cold the car would mis fire unless the ecu was warmed in front of a fan heater, don't know why this was the case,esp with 2 ecu's, the only thing in common was the pectal board and chip. so for this reason I'm offering them as spares or repairs I've spent good money on them but would like £50 each, 1 had a fan fitted, I think I have the fan cover somewhere. pectal board and chip not included.
gambo08
Feb 4, 2016 10:49 PM
Oct 1, 2015 02:00 PM
fordrallycar
Sep 30, 2015 07:57 PM
Fordmad!
Sep 29, 2015 07:03 PM
